Full Version: SABnzbd Suite not working anymore?
Has the SABnzbd suite add-on been discontinued? I followed the instructions here but that did not work. All I get in the add-ons section is "boblightd" , "tvheadend" & "vdr-addon"
Does anyone have a clue on this? Tried searching the forum but got nowhere.
I don't see it either, I installed latest 3.2.3 fusion build and the Sabnzbd suite is no longer present.
Where did it go?
For some reason some dude removed it from OpenElec
https://github.com/OpenELEC/OpenELEC.tv/...0080e68c68
So it was moved to the unofficial repos, to install XBMC unofficial repos, read the following page: http://openelec.tv/news/20-project/102-n...addon-repo
Basically, you have to download the unofficial xbmc repo zip file (located here http://unofficial.addon.pro/addons/3.1/G...-3.0.0.zip, for example for x86_64 system), and copy to your XBMC and install Add-on from zip file.
Once you do that, there will be a new category called something like XBMC Unofficial addons and SABnzbd-Suite will be somewhere in there.
