Full Version: An Error Has Occurred
Just upgraded from one of the earlier versions (1.3.0.10) to the newest version of EMM as it seemed that scraping kinda broke and wasn't grabbing any background or fanart. Made a backup of my existing version and then moved the new version in and replaced any existing files. Modified my db so that it would work with the new version per the instructions in another thread.
Now when rescraping a movie I get two errors that pop up, both say "An Error Has Occurred HTTP Error". Everything scrapes fine now and I don't see any issues resulting from the error, just want to make sure something else isn't wrong now.
This is my log file after restarting EMM and starting a rescrape on a movie.
================= <Assembly Versions> =================
Platform: x86
Ember Application (Revision: 1.3.0.15)
Ember API (Revision: 1.3.0.15)
Ember Extras Scraper (Revision: 1.3.0.12)
Ember Native Movie Scrapers (Revision: 1.3.0.15)
Ember TMDB Movie Scrapers (Revision: 1.3.0.15)
Ember XML Scraper (Revision: 1.3.0.5)
Renamer (Revision: 1.3.0.12)
Frame Extractor (Revision: 1.3.0.12)
Media File Manager (Revision: 1.3.0.5)
Movie List Exporter (Revision: 1.3.0.12)
NMT Jukebox Builder (Revision: 1.3.0.13)
Notifications (Revision: 1.3.0.14)
Offline Media Manager (Revision: 1.3.0.15)
Web Server (Revision: 1.3.0.5)
XBMC Controller (Revision: 1.3.0.5)
Boxee Compatibility (Revision: 1.3.0.12)
MediaBrowser Compatibility (Revision: 1.3.0.12)
YAMJ Compatibility (Revision: 1.3.0.12)
Genres Editor (Revision: 1.3.0.12)
Media Sources Editor (Revision: 1.3.0.12)
Audio & Video Codec Mapping (Revision: 1.3.0.12)
Trakt Settings (Revision: 1.3.0.12)
Ember Native TV Scrapers (Revision: 1.3.0.15)
Title: Error
Message: The request was aborted: The request was canceled.
StackTrace:    at System.Net.HttpWebRequest.GetResponse()
   at EmberAPI.HTTP.DownloadImage()
Date/Time: 10/9/2013 4:39:28 PM
Title: Error
Message: HTTP Error
StackTrace:
Date/Time: 10/9/2013 4:40:37 PM
Title: Error
Message: HTTP Error
StackTrace:
You can ignore this errors =)
Perfect thanks Smile
