Full Version: 181 radio station stuttering
This is running on my Gbox, It's not a bandwidth issue as I can stream my HD movies over upnp no problem, as well as countless other things. Is there anything I can do to stop this from happening? It seems to "skip" or judder every few seconds when listening to the radio.
Are you using an add-on to listen to this station or just a *.strm (or similar) file to access the stream directly from the site? Have you tried listening to this station via a web browser and does it have the same problem?
Hi pal, I'm using the add on. The web version doesn't have the same prob so it must be something to do with my box.
Which add-on? An XBMC one or an Android app on your Gbox?
It's an xbmc one. This one here pal. http://www.xbmchub.com/forums/official-x...81-fm.html
Best you ask over on the site that provides and supports this add-on as it's not one of ours.
Will do.
