Full Version: Language Plot
Hi all
i don't know what the trick now but i have download the last version and i want have all info from imdb and only the plot with TMDB in french .. i try above 30 min and i can't find the tricks ...
is the pass i used the olympia script but am sure now work without that ..
Native scraper is english only. If you want use the tmdb scraper, you need a personal API key.
yes Dan i have do and i use my API key but the PLOT CASE is empty when i finished the scrape ...
(2013-10-11, 18:56)MaxCore Wrote: [ -> ]yes Dan i have do and i use my API key but the PLOT CASE is empty when i finished the scrape ...
Movie name?
humm i try with 8 mile
i can screen my config if you want Dan
I've only just seen that you tried to mix 2 scraper. This does not work in version 1.3.x unfortunately.
This will work only in version 1.4.x without error.
ok! i will wait Wink thx for support !
