2014-04-19, 17:41
2014-04-21, 00:23
I found out one file that is playing well with libstagefright but not with MediaCodec, I'm having lots of stuttering, is like if the movie is in slow motion.
I'm sending the logs that first use mediacodec and then libstagefright.
http://pastebin.com/raw.php?i=qi9tnXUn
2014-04-21, 11:11
Tried beta 4 (LG G2 Snapdragon 800)
Software and stagefright OK
Mediacodec crash on LiveTV (XBMC FC)
Mediacodec OK on HD Videos through smb share
Thanks,
sdf
Thanks,
sdf
2014-04-21, 11:14
(2014-04-21, 11:11)sdfg Wrote: [ -> ]Tried beta 4 (LG G2 Snapdragon 800)
Thanks,
sdf
where are the crashlogs please?....
2014-04-21, 18:57
Sorry, can't post them now. Will do as soon as possible
Thank you,
sdf
Thank you,
sdf
2014-04-21, 19:20
Here are the logs (did't find a crashlog)
http://pastebin.com/TtYMnc24
2014-04-22, 18:13
To get a usable log to debug a reproducable crash please acquire a logcat (wiki)
2014-04-24, 08:51
2014-04-26, 12:44
Beta 4 feedback: mediacodec still only plays big buck bunny -- everything else just plays audio no video (the theme background shows).
Logs: http://xbmclogs.com/show.php?id=186171
All the other files play fine with mx player and to varying degrees of success with libstagefreight.
2014-05-20, 13:28
My xbmc crash and exit during LiveTV on android:
05-20 10:20:39.807 D/dalvikvm(11080): GC_CONCURRENT freed 384K, 56% free 2999K/6692K, paused 1ms+1ms, total 16ms
05-20 10:20:51.187 V/XBMC (11080): 10:20:51 T:1879678488 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
05-20 10:20:51.387 D/dalvikvm( 1340): GC_CONCURRENT freed 402K, 21% free 3713K/4696K, paused 2ms+1ms, total 15ms
05-20 10:20:51.487 D/dalvikvm( 1340): GC_CONCURRENT freed 402K, 21% free 3715K/4696K, paused 2ms+1ms, total 14ms
05-20 10:20:51.587 V/XBMC (11080): 10:20:51 T:1879678488 INFO: CDVDPlayerVideo - Stillframe detected, switching to forced 25.000000 fps
05-20 10:20:51.587 V/XBMC (11080): 10:20:51 T:1879678488 DEBUG: CPullupCorrection: pattern lost on diff 200000.000000
05-20 10:20:51.587 V/XBMC (11080): 10:20:51 T:1879678488 ERROR: CDVDMediaCodecInfo::ReleaseOutputBuffer ExceptionOccurred render(1)
05-20 10:20:51.587 W/System.err(11080): java.lang.IllegalStateException
05-20 10:20:51.587 W/System.err(11080): at android.media.MediaCodec.releaseOutputBuffer(Native Method)
05-20 10:20:51.587 W/System.err(11080): at dalvik.system.NativeStart.run(Native Method)
05-20 10:20:51.647 W/System.err(11080): java.lang.IllegalStateException
05-20 10:20:51.647 W/System.err(11080): at android.media.MediaCodec.releaseOutputBuffer(Native Method)
05-20 10:20:51.647 W/System.err(11080): at dalvik.system.NativeStart.run(Native Method)
05-20 10:20:51.697 W/System.err(11080): java.lang.IllegalStateException
05-20 10:20:51.697 W/System.err(11080): at android.media.MediaCodec.releaseOutputBuffer(Native Method)
05-20 10:20:51.697 W/System.err(11080): at dalvik.system.NativeStart.run(Native Method)
here the full log of android:
http://xbmclogs.com/show.php?id=205874
xbmc.old.log is clean, i'll post a new one soon!
2014-05-24, 11:18
2014-05-28, 06:44
Hi, I'm running this:
My configuration:
When I play a file that uses Mediacodec, the timecode is always at 0:00:00. This is not a big problem but it would be nice if you can maybe look at this... I love the resuming function in XBMC.
I noticed that some Anime are encoded in weird codecs so MediaCodec will revert back to software rendering. In those cases, the timecode works fine.
Here is my debug log
Actions I took:
When using libstagefright, certain videos run more smoothly, but I also have a problem with that codec in that if I stop a video, the next video would not show fullscreen video. I would need to exit XBMC and restart it to watch the next video.
So what I'm saying is that if this timecode problem with Mediacodec can be solved, it would really make XBMC perfect for me on this tablet.
- Hardware: Nook HD+
- Rom: CM11 nightly 2014-05-05
- XBMC Nightly 20140511
My configuration:
- Hardware Encoding: On
- Libstagefright: Off
- MediaCodec: On
Actions I took:
- Start XBMC
- Enable Debug Log
- Start a video and ensured that timecode is always 0:00:00
- Stop video and disable debug log
2014-07-09, 21:55
Hi.. I just install xbmc in my new nexus 2013 lte and I have a bug with mediacodec hardware acceleration. h264 1080p 24 decoding works well but when i try to watch mpeg2/h264 interlaced live tv or a ts interlaced recording xbmc crashes as soon as it start to play (i hear for a second the audio but the video never starts and crashes).
Here's the log:
http://xbmclogs.com/show.php?id=243445
And here's the logcat:
https://dl.dropboxusercontent.com/u/2219...acodec.txt
with dalvik:
I tried to switch to dalvik and i got the same result:
Here's the log:
http://xbmclogs.com/show.php?id=244244
https://dl.dropboxusercontent.com/u/2219...dalvik.txt
My configuration:
Here's the log:
with dalvik:
Here's the log:
- Hardware: Nexus 7 2013 LTE
- Rom: KitKat 4.4.3 stock
- XBMC Gotham 13.1
My configuration:
- MediaCodec: On
2014-07-10, 18:49
Using ART, are you.
There will be some fixes for ART in the coming 13.2.
2014-07-11, 01:28
(2014-07-10, 18:49)Koying Wrote: [ -> ]Using ART, are you.
Here's the log:
btw when will be out this 13.2 and these fixes are already in helix alphas?
