2013-10-13, 20:36
Hello, I am a newbie so forgive the ignorance. I have my movie collection on a Buffalo linkstation I can access my movies in xbmc but it will not pull metadata. I thought this was my solution but when I start the myxbmc html I get a message Unhandled exception has occurred and then this log:
When I press continue and scan it says 0 library.
Any help is greatly appreciated. Also, I have stored all my files in separate folders with name format like: The Bicycle Thief (1948) all mk4 files.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.ExternalException (0x80004005): A generic error occurred in GDI+.
at System.Drawing.Image.Save(String filename, ImageCodecInfo encoder, EncoderParameters encoderParams)
at System.Drawing.Image.Save(String filename, ImageFormat format)
at System.Drawing.Image.Save(String filename)
at DeadSix_myXBMCHTML.Form_Main.showForm() in c:\Users\Hagen\Documents\myxbmc-html-generator\XBMCManager\Form_Main.cs:line 173
at DeadSix_myXBMCHTML.Form_Splash.tmr_Tick(Object sender, EventArgs e) in c:\Users\Hagen\Documents\myxbmc-html-generator\XBMCManager\Form_Splash.cs:line 81
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.1008 (RTMGDR.030319-1000)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
DeadSix_myXBMCHTML
Assembly Version: 6.6.1.18826
Win32 Version: 6.6.1.0
CodeBase: file:///C:/Users/Greg/AppData/Local/DeadSix/XBMC%20HTML%20Generator/DeadSix_myXBMCHTML.exe
Win32 Version: 4.0.30319.1002 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.1001 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.0.30319.233 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 10.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System.Management
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Xml
Win32 Version: 4.0.30319.1015 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Newtonsoft.Json
Assembly Version: 4.5.0.0
Win32 Version: 5.0.6.16206
CodeBase: file:///C:/Users/Greg/AppData/Local/DeadSix/XBMC%20HTML%20Generator/Newtonsoft.Json.DLL
Microsoft.CSharp
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
System.Data.SQLite
Assembly Version: 1.0.88.0
Win32 Version: 1.0.88.0
CodeBase: file:///C:/Users/Greg/AppData/Local/DeadSix/XBMC%20HTML%20Generator/System.Data.SQLite.DLL
System.Data
Win32 Version: 4.0.30319.237 (RTMGDR.030319-2300)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.Configuration
Win32 Version: 4.0.30319.1015 (RTMGDR.030319-1000)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.EnterpriseServices
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Numerics
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.ComponentModel.DataAnnotations
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
System.Runtime.Serialization
Win32 Version: 4.0.30319.1016 (RTMGDR.030319-1000)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Dynamic
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
Anonymously Hosted DynamicMethods Assembly
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
Microsoft.WindowsAPICodePack.Shell
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Users/Greg/AppData/Local/DeadSix/XBMC%20HTML%20Generator/Microsoft.WindowsAPICodePack.Shell.DLL
CodeBase: file:///C:/Users/Greg/AppData/Local/DeadSix/XBMC%20HTML%20Generator/Microsoft.WindowsAPICodePack.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
mscorlib
DeadSix_myXBMCHTML
System.Drawing
System
System.Core
System.Management
System.Xml
Newtonsoft.Json
Microsoft.CSharp
System.Data.SQLite
System.Data
System.Transactions
System.Numerics
System.Xml.Linq
System.Dynamic
enabled.
For example:
<configuration>
</configuration>
