Thanks for the input. I believe my TV is capable of 5.1 over HDMI, I have an Xbox360, PS3, and a cable box that are all hooked up the same way and play through the 5.1 system fine (or at least sound much much better than the RL70) so i think it has to be something going on with the RL70. I have tried using the drivers that came with the pc as well as the updated AMD drivers but I have the same result. I will post my log file if you can help me out, I would appreciate it.
12:11:16 T:4836 NOTICE: -----------------------------------------------------------------------
12:11:16 T:4836 NOTICE: Starting XBMC (12.2 Git:20130502-32b1a5e), Platform: Windows 7 64-bit, build 7600. Built on May 2 2013 (compiler 1600)
12:11:16 T:4836 NOTICE: AMD E-450 APU with Radeon(tm) HD Graphics
12:11:16 T:4836 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
12:11:16 T:4836 NOTICE: Running with administrator rights
12:11:16 T:4836 NOTICE: Aero is enabled
12:11:16 T:4836 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
12:11:16 T:4836 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
12:11:16 T:4836 NOTICE: special://masterprofile/ is mapped to: C:\Users\Media\AppData\Roaming\XBMC\userdata
12:11:16 T:4836 NOTICE: special://home/ is mapped to: C:\Users\Media\AppData\Roaming\XBMC\
12:11:16 T:4836 NOTICE: special://temp/ is mapped to: C:\Users\Media\AppData\Roaming\XBMC\cache
12:11:16 T:4836 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
12:11:16 T:4836 NOTICE: Local hostname: MediaBot
12:11:16 T:4836 NOTICE: Log File is located: C:\Users\Media\AppData\Roaming\XBMC\xbmc.log
12:11:17 T:4836 NOTICE: Found 2 Lists of Devices
12:11:17 T:4836 NOTICE: Enumerated DirectSound devices:
12:11:17 T:4836 NOTICE: Device 1
12:11:17 T:4836 NOTICE: m_deviceName : {490D97DD-3CA6-4741-8D10-C949298485DD}
12:11:17 T:4836 NOTICE: m_displayName : HDMI - AMD HDMI Output (AMD High Definition Audio Device)
12:11:17 T:4836 NOTICE: m_displayNameExtra: DirectSound: AMD HDMI Output (AMD High Definition Audio Device)
12:11:17 T:4836 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
12:11:17 T:4836 NOTICE: m_channels : FL,FR
12:11:17 T:4836 NOTICE: m_sampleRates : 48000
12:11:17 T:4836 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
12:11:17 T:4836 NOTICE: Device 2
12:11:17 T:4836 NOTICE: m_deviceName : {4166BFCB-9C2D-4984-AEEC-034350268C67}
12:11:17 T:4836 NOTICE: m_displayName : SPDIF - Realtek Digital Output (Realtek High Definition Audio)
12:11:17 T:4836 NOTICE: m_displayNameExtra: DirectSound: Realtek Digital Output (Realtek High Definition Audio)
12:11:17 T:4836 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
12:11:17 T:4836 NOTICE: Enumerated WASAPI devices:
12:11:17 T:4836 NOTICE: m_displayNameExtra: WASAPI: Realtek Digital Output (Realtek High Definition Audio)
12:11:17 T:4836 NOTICE: m_sampleRates : 96000,48000,44100
12:11:17 T:4836 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
12:11:17 T:4836 NOTICE: m_displayNameExtra: WASAPI: AMD HDMI Output (AMD High Definition Audio Device)
12:11:17 T:4836 NOTICE: m_sampleRates : 48000,44100,32000
12:11:17 T:4836 NOTICE: m_dataFormats : AE_FMT_DOUBLE,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S32NE,AE_FMT_S32LE,AE_FMT_S32BE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_S8,AE_FMT_U8
12:11:17 T:4836 NOTICE: load settings...
12:11:17 T:4836 NOTICE: special://profile/ is mapped to: special://masterprofile/
12:11:17 T:4836 NOTICE: loading special://masterprofile/guisettings.xml
12:11:17 T:4836 NOTICE: Getting hardware information now...
12:11:17 T:4836 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
12:11:17 T:4836 NOTICE: Loaded playercorefactory configuration
12:11:17 T:4836 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
12:11:17 T:4836 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
12:11:17 T:4836 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
12:11:17 T:4836 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
12:11:17 T:4836 NOTICE: Default DVD Player: dvdplayer
12:11:17 T:4836 NOTICE: Default Video Player: dvdplayer
12:11:17 T:4836 NOTICE: Default Audio Player: paplayer
12:11:17 T:4836 NOTICE: Disabled debug logging due to GUI setting. Level 0.
12:11:17 T:4836 NOTICE: Log level changed to 0
12:11:17 T:4836 NOTICE: Loading media sources from special://masterprofile/sources.xml
12:11:17 T:2728 NOTICE: Thread CSoftAE start, auto delete: false
12:11:17 T:4836 NOTICE: Running database version Addons15
12:11:17 T:4836 NOTICE: Found screen: Generic PnP Monitor on AMD Radeon HD 6300 series Graphics, adapter 0.
12:11:17 T:4836 NOTICE: Primary mode: 1920x1080 @ 60.00 - Full Screen
12:11:17 T:2724 NOTICE: Thread CRemoteControl start, auto delete: false
12:11:17 T:1368 NOTICE: Thread XBMC Peripherals start, auto delete: false
12:11:17 T:4836 NOTICE: Previous line repeats 1 times.
12:11:17 T:4836 NOTICE: Additional mode: 640x480 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 640x480 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 640x480 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 640x480 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 640x480 @ 59.94 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 640x480 @ 67.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 640x480 @ 72.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 640x480 @ 75.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x480 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x480 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x480 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x480 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x480 @ 59.94 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x576 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x576 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x576 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x576 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x576 @ 50.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x576 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Previous line repeats 2 times.
12:11:17 T:4836 NOTICE: Additional mode: 720x576 @ 72.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 720x576 @ 75.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x480 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x480 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x480 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x480 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x480 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x480 @ 72.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x480 @ 75.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x600 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x600 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x600 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x600 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x600 @ 72.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 800x600 @ 75.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x600 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x600 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x600 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x600 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x600 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x600 @ 70.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x600 @ 75.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x768 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x768 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x768 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x768 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x768 @ 70.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1024x768 @ 75.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1152x648 @ 59.94 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1152x648 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1152x864 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1152x864 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1152x864 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1152x864 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1152x864 @ 59.94 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1152x864 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1152x864 @ 75.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x720 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x720 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x720 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x720 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x720 @ 50.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x720 @ 59.94 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x768 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x768 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x768 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x768 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x800 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x800 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x800 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x800 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x1024 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x1024 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x1024 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x1024 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1280x1024 @ 75.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1360x768 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1360x768 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1360x768 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1360x768 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1360x768 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1400x1050 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1400x1050 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1400x1050 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1400x1050 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1400x1050 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1440x900 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1440x900 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1440x900 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1440x900 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1440x900 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1440x900 @ 75.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1600x900 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1600x900 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1600x900 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1600x900 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1600x900 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1600x1200 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1680x1050 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1680x1050 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1680x1050 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1680x1050 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1680x1050 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1776x1000 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1776x1000 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1776x1000 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1776x1000 @ 59.94 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1776x1000 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1776x1000 @ 29.97i - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1776x1000 @ 30.00i - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1920x1080 @ 24.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1920x1080 @ 23.98 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1920x1080 @ 30.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1920x1080 @ 29.97 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1920x1080 @ 50.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1920x1080 @ 60.00 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1920x1080 @ 59.94 - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1920x1080 @ 30.00i - Full Screen
12:11:17 T:4836 NOTICE: Additional mode: 1920x1080 @ 29.97i - Full Screen
12:11:17 T:4836 NOTICE: Checking resolution 16
12:11:18 T:4836 NOTICE: Running database version Addons15
12:11:18 T:4836 NOTICE: Running database version ViewModes4
12:11:18 T:4836 NOTICE: Running database version Textures13
12:11:18 T:4836 NOTICE: Running database version MyMusic32
12:11:18 T:4836 NOTICE: Running database version MyVideos75
12:11:18 T:4836 NOTICE: Running database version TV22
12:11:18 T:4836 NOTICE: Running database version Epg7
12:11:18 T:4836 NOTICE: initializing playlistplayer
12:11:18 T:4836 NOTICE: DONE initializing playlistplayer
12:11:19 T:4836 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
12:11:19 T:4836 NOTICE: initialize done
12:11:19 T:284 NOTICE: Thread CVideoInfoScanner start, auto delete: false
12:11:19 T:284 NOTICE: VideoInfoScanner: Starting scan ..
12:11:19 T:4836 NOTICE: Running the application...
12:11:20 T:4116 NOTICE: Thread Jobworker start, auto delete: true
12:11:20 T:4836 NOTICE: ES: Starting event server
12:11:20 T:940 NOTICE: Thread CEventServer start, auto delete: false
12:11:20 T:940 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
12:11:20 T:940 NOTICE: UDP: Listening on port 9777
12:11:20 T:3024 NOTICE: Thread CTCPServer start, auto delete: false
12:11:21 T:4784 NOTICE: Thread CRssReader start, auto delete: false
12:11:21 T:2888 NOTICE: Thread Jobworker start, auto delete: true
12:11:24 T:920 NOTICE: Thread Jobworker start, auto delete: true
12:11:24 T:284 NOTICE: Previous line repeats 1 times.
12:11:26 T:284 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:06
12:11:29 T:4468 NOTICE: Thread Background Loader start, auto delete: false
12:11:30 T:2728 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:21432, P:10848, O:21168.
12:11:42 T:4836 NOTICE: DVDPlayer: Opening: D:\Movies\Captain Ron.(1992).wmv
12:11:42 T:4836 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
12:11:42 T:3004 NOTICE: Thread CDVDPlayer start, auto delete: false
12:11:42 T:3004 NOTICE: Creating InputStream
12:11:42 T:3004 NOTICE: Creating Demuxer
12:11:42 T:3004 NOTICE: Opening video stream: 1 source: 256
12:11:42 T:3004 NOTICE: Creating video codec with codec id: 18
12:11:42 T:3004 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: Windows Media Video 7
12:11:42 T:3004 NOTICE: Creating video thread
12:11:42 T:3004 NOTICE: Opening audio stream: 0 source: 256
12:11:42 T:3004 NOTICE: Finding audio codec for: 86024
12:11:42 T:3612 NOTICE: Thread CDVDPlayerVideo start, auto delete: false
12:11:42 T:3612 NOTICE: running thread: video_thread
12:11:42 T:3004 NOTICE: Creating audio thread
12:11:42 T:4796 NOTICE: Thread CDVDPlayerAudio start, auto delete: false
12:11:42 T:4796 NOTICE: running thread: CDVDPlayerAudio::Process()
12:11:42 T:4796 NOTICE: Creating audio stream (codec id: 86024, channels: 2, sample rate: 44100, no pass-through)
12:11:42 T:3612 NOTICE: fps: 29.970030, pwidth: 320, pheight: 240, dwidth: 320, dheight: 240
12:11:42 T:3612 NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.00 - Full Screen (16)
12:12:38 T:4836 NOTICE: CDVDPlayer::CloseFile()
12:12:38 T:4836 NOTICE: DVDPlayer: waiting for threads to exit
12:12:38 T:3004 NOTICE: CDVDPlayer::OnExit()
12:12:38 T:3004 NOTICE: DVDPlayer: closing audio stream
12:12:38 T:3004 NOTICE: Closing audio stream
12:12:38 T:3004 NOTICE: Waiting for audio thread to exit
12:12:38 T:4796 NOTICE: thread end: CDVDPlayerAudio::OnExit()
12:12:38 T:3004 NOTICE: Closing audio device
12:12:38 T:3004 NOTICE: Deleting audio codec
12:12:38 T:3004 NOTICE: DVDPlayer: closing video stream
12:12:38 T:3004 NOTICE: Closing video stream
12:12:38 T:3004 NOTICE: waiting for video thread to exit
12:12:38 T:3612 NOTICE: thread end: video_thread
12:12:38 T:3004 NOTICE: deleting video codec
12:12:38 T:3004 NOTICE: CDVDPlayer::OnExit() deleting demuxer
12:12:38 T:3004 NOTICE: CDVDPlayer::OnExit() deleting input stream
12:12:38 T:4836 NOTICE: DVDPlayer: finished waiting
12:12:38 T:4228 NOTICE: Thread Background Loader start, auto delete: false
12:12:39 T:4836 NOTICE: CDVDPlayer::CloseFile()
12:12:39 T:4836 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
12:12:39 T:4836 NOTICE: DVDPlayer: waiting for threads to exit
12:12:39 T:4836 NOTICE: DVDPlayer: finished waiting
12:12:39 T:4756 NOTICE: Thread Jobworker start, auto delete: true
12:12:48 T:4836 NOTICE: Storing total System Uptime
12:12:48 T:4836 NOTICE: Saving settings
12:12:48 T:4836 NOTICE: stop all
12:12:48 T:4836 NOTICE: ES: Stopping event server
12:12:48 T:4836 NOTICE: stopping zeroconf publishing
12:12:48 T:940 NOTICE: ES: UDP Event server stopped
12:12:48 T:4836 NOTICE: stop sap announcement listener
12:12:48 T:4836 NOTICE: clean cached files!
12:12:48 T:4836 NOTICE: unload skin
12:12:48 T:4836 NOTICE: stop python
12:12:49 T:4836 NOTICE: stopped
12:12:49 T:4836 NOTICE: destroy
12:12:49 T:4836 NOTICE: closing down remote control service
12:12:49 T:4836 NOTICE: unload sections
12:12:50 T:4836 NOTICE: destroy
12:12:50 T:4836 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
12:12:50 T:4836 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
12:12:50 T:4836 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
12:12:50 T:4836 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
12:12:50 T:4836 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
12:12:50 T:4836 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
12:12:50 T:4836 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
12:12:50 T:4836 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
12:12:50 T:4836 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
12:12:50 T:4836 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
12:12:50 T:4836 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
12:12:50 T:4836 NOTICE: closing down remote control service
12:12:50 T:4836 NOTICE: unload sections
12:12:50 T:4836 NOTICE: application stopped...
