Full Version: Some questions for getting my EMM optimized:
Some questions:
1. I'm using Ember Native Movie Scrapers, but is it better to enable TMDB instead and disable Native?
2. I have scraped all my movies with trailer to .nfo but would like to download them locally now. Can I do that and get Ember to delete the links and more importantly do I have to refresh all my movies in XBMC or can it find the local trailers without having to rescrape?
3. When I want to get the best quality trailers, do I need to do anything special to get the correct scraper working? Many of the trailers are 6 MB or so even when I set 720p in preferences.
Any help?
1. The native scraper works better and near error-free.
2. Ember can't remove trailer links automatically.
3. All Trailer links are from TMDB. It depends on what trailers are stored on TMDB.
Thanks for the answer Dan. I have first seen your answer now.
Regarding the trailer removal, is it possible to get XBMC to prioritize local trailers when building a library?
Am I correct to assume that you have to build a new library in XBMC to get it to recognize local trailers when I download them to my existing library?
