2013-10-14, 23:19
I need help/advice for subtitles in XBMC.
The problem is, regardless of the software (XBMC, XBMC+DSPlayer, XBMC+external player like MPC-HC or PotPlayer, ...), I have different behavior with subtitles. I don't know if the problem is identical for english audio/subtitle, but I have the problem for french audio/subtitle.
Before giving my result, I will list some properties of these three movies that I know I have the problem :
Avatar (BD-ISO)
Audio : One for each language
Subtitles : One for each language
The Hobbit (BD-ISO)
subtitles : Two for each language (the first one appear throughout the movie, the second appear only when need)
Star Trek Into Darkness (BD-ISO)
Below, I give result from the last monthly built (alpha 8), but I have the same problem with 12.0 and 12.2. Also, when I'm telling "when need", I mean that subtitles appear only on special occasion. ex: when a character speak in Na'vi, Elvish, klingon, etc.
By default, on a new XBMC installation, subtitles are enabled. In System, I changed the default language for audio and subtitle to French.
Result 1 (subtitle enabled)
Avatar : When need
The Hobbit : Throughout the movie because the first subtitle is use by default
Star Trek : Throughout the movie
If, by default, I disable subtitle, I get :
Result 2 (subtitle disabled)
Avatar : No subtitle. I must enable it if I want to see subtitle "when need".
The Hobbit : No subtitle. I must enable it and select the second french subtitle
Star Trek : when need (Probably a forced subtitle)
I also tried with XBMC+DSPlayer, DSPlayer with external filter... but every time it is tricky and I cannot find a solution for every files. If I use software like PowerDVD or TMT, I don't have this problem. Maybe these software are using some information in index.bdmv to determine if it must enable or not a subtitle? I don't know. The problem is that these software are not free and I would prefer a solution for XBMC. But actually, an integration of TMT within XBMC seems to be the only working solution.
I hope you have suggestion, because I already spent a lot of time trying many options. Maybe it will be more fast/easy with your suggestions
* Also, maybe someone will suggest converting these movies in mkv. The idea is not bad, but you must know that I have more than one thousand of movies (ISO of real BD/DVD media). It will take a lot of time to convert these movies, verify if everything is working and if I have everything (full movie, bonus, all subtitles, some movies have multiple movie length on the same disk, multi-angle, ...).
Avatar (BD-ISO)
The Hobbit (BD-ISO)
Avatar : When need
