2013-10-17, 03:11
I had setup my TV Shows and Movies and all were showing in the Library, the issue was a TV shows episodes were listed 3x each.
I went into Settings and cleaned the library but it removed the entire series though the folder still shows up under files.
I have added a "tvshow.nfo" file and the spelling/naming convention are correct, no help.
When the library tries to update it finds the TV show and immediately stops the update scan.
I would rather not have to remove and re-add the TV Shows video source.
Any ideas?
Thanks,
Will
Any ideas?
Thanks,
Will
