Full Version: sudo install apt-get mythbuntu-control-center cannot locate package
Hi - newb here...
Want to install mythtv on my Live USB Xbmcbuntu - but am missing something basic i'm sure:
1. CTRL + ALT + F1 to get terminal
2. sudo apt-get install mythbuntu-control-centre
3. result is ... "E: Cannot locate package "
Please can someone educate me what i'm doing wrong?
Thx!
sudo apt-get install mythtv or sudo apt-get install mythbuntu-control-centre
My apologies - typo in first post now corrected - it was syntax you suggested black_eagle but same error still...
What is 'live usb xbmcbuntu'? Did you dovan install?
I have created a bootable USB drive of Xbmcbuntu... And am running Xbmc in Live mode... Not installed on the HDD of the hardware...
Thats your problem then.
