Hello miappa
Updated script, tried 20141103 build, same situation. Remote works left right up and down, but no select.
I want to create a debug log, but can't get into the menu
Can someone remind me of the entry into advancesettings.xml, and I'll reboot and get the log onto pastebin.
Right.
Log file with <loglevel>1</loglevel> in advancedsettings.xml
http://pastebin.com/G1TbZPmn
Hope it gives some insight.
Also, typing irw or sudo irw from prompt only gives me
pi@raspbmc:~$ irw
connect: No such file or directory
pi@raspbmc:~$ sudo irw
pi@raspbmc:~$
Can you post the content of /scripts/xbmc-watchdog.sh.
I've switched back, would that make a difference?
Yes, then it will be different... however, I wanted to make sure that you hade the updated Kodi version of that script as eventlircd seems to not run for you.
And, as I mentioned previously, I made a mistake regarding the naming which several of the upstart scripts (including eventlircd) depends on.
I had the same problem before the fix, but now eventlircd starts and I can at least run irw.
Edit: I have missed to include a script which is probably the cause of this issue...
running 20141019 again, watchdog.sh is as follows:
#!/bin/bash
FBSET="/bin/fbset"
if [ -e $FBSET ]; then
if [ ! -f /tmp/fb_resolution ]; then
FB_RESOLUTION=$(fbset | grep geometry | awk '{print "-xres "$2" -yres "$3" -vxres "$4" -vyres "$5}')
echo $FB_RESOLUTION > /tmp/fb_resolution
fi
fi
while true
do
# detach fb to save gpu memory
echo 0 > /sys/class/vtconsole/vtcon1/bind
fbset -xres 1 -yres 1 -vxres 1 -vyres 1
else
chvt 1
set +v
tput civis
tput setf 0
start --no-wait splash
clear
fi
if [ ! -h /home/pi/.xbmc-current ]; then
if [ -e /home/pi/.xbmc-current ]; then
rm -rf /home/pi/.xbmc-current
fi
su - pi -c "ln -s /opt/xbmc-bcm /home/pi/.xbmc-current"
ldconfig
fi
if [ -f /etc/ld.so.cache ]; then
xbmc_libs=$(grep .xbmc-current /etc/ld.so.cache)
else
xbmc_libs=""
fi
if [ ! -f /boot/config.txt ]; then
# treat Raspbmc Settings nicely
touch /boot/config.txt
fi
test "x$xbmc_libs" != "x" || ldconfig
setcap cap_net_admin,cap_net_bind_service,cap_net_raw=ep /home/pi/.xbmc-current/xbmc-bin/lib/xbmc/xbmc.bin
date -u +%s > /var/run/splash-timestamp
if [ -f /home/pi/.xbmc/userdata/addon_data/script.raspbmc.settings/settings.xml ]
then
# Check for sound card
grep sys.xbmc.sc /home/pi/.xbmc/userdata/addon_data/script.raspbmc.settings/settings.xml | grep -q true
if [ $? = 0 ]
then
modprobe snd_soc_bcm2708
modprobe snd_soc_bcm2708_i2s
modprobe bcm2708_dmaengine
modprobe snd_soc_pcm512x
modprobe snd_soc_iqaudio_dac
modprobe snd_soc_pcm5102a
modprobe snd_soc_hifiberry_dac
fi
fi
if [ -f /usr/lib/libcofi_rpi.so ]; then
su - pi -c "export XBMC_HOME=$(readlink /home/pi/.xbmc-current)'/xbmc-bin/share/xbmc' ; LD_PRELOAD=/usr/lib/libcofi_rpi.so /home/pi/.xbmc-current/xbmc-bin/lib/xbmc/xbmc.bin --standalone -fs --lircdev /var/run/lirc/lircd 2>&1 | logger -t xbmc"
else
su - pi -c "export XBMC_HOME=$(readlink /home/pi/.xbmc-current)'/xbmc-bin/share/xbmc' ; /home/pi/.xbmc-current/xbmc-bin/lib/xbmc/xbmc.bin --standalone -fs --lircdev /var/run/lirc/lircd 2>&1 | logger -t xbmc"
fi
last_execute_time=$(cat /var/run/splash-timestamp)
current_time=$(date -u +%s)
time_diff=$(($current_time - $last_execute_time))
#TO DO: xbmc-troubleshooting.py script
#test "$time_diff" -le 30 || /scripts/xbmc-troubleshooting.py
case "$?" in
0) # user quit. Wait for 60s grace period so user can login into console tty*
# reattach fb
if [ -f /tmp/fb_resolution ]; then
fbset `cat /tmp/fb_resolution`
fi
echo 1 > /sys/class/vtconsole/vtcon1/bind
DEPTH2=$(fbset | head -3 | tail -1 | cut -d " " -f 10)
if [ "$DEPTH2" = "8" ]; then
DEPTH1=16
elif [ "$DEPTH2" = "16" ]; then
DEPTH1=8
elif [ "$DEPTH2" = "32" ]; then
DEPTH1=8
else
DEPTH1=8
DEPTH2=16
fi
fbset -depth $DEPTH1 && fbset -depth $DEPTH2
start console-setup
echo -e "\033c" > /dev/tty1
fi
dialog --title "Raspbmc" --infobox "Relax, XBMC will restart shortly.\n\nPress ESC key for a command line" 0 0 > /dev/tty1
read -sn 1 -t 10 press < /dev/tty1
if [ "$press" = $'\e' ]; then
# user pressed escape. now switching to 2nd terminal
chvt 2
set -v
tput cnorm
tput setf 7
sleep 55
while true
do
login_check=$(who | awk '{print $2}' | grep ^tty[0-9])
if [ "$login_check" = "" ]; then
break
fi
sleep 5
done
else
# no user input. resume xbmc
sleep 2
fi;;
64) # shutdown system.
set -v
tput cnorm
tput setf 7
sleep 60 ;;
65) # warm Restart xbmc
sleep 2 ;;
66) # Reboot System
set -v
tput cnorm
tput setf 7
sleep 60 ;;
*) # this should not happen
set -v
tput cnorm
tput setf 7
sleep 30 ;;
esac
done
Running 20141103-nc4
#!/bin/bash
FBSET="/bin/fbset"
fi
fi
while true
do
else
chvt 1
set +v
tput civis
tput setf 0
clear
fi
fi
ldconfig
fi
else
xbmc_libs=""
fi
fi
setcap cap_net_admin,cap_net_bind_service,cap_net_raw=ep /home/pi/.xbmc-current/xbmc-bin/lib/kodi/kodi.bin
then
if [ $? = 0 ]
then
fi
fi
su - pi -c "export APP_HOME=$(readlink /home/pi/.xbmc-current)'/xbmc-bin/share/kodi' ; LD_PRELOAD=/usr/lib/libcofi_rpi.so /home/pi/.xbmc-current/xbmc-bin/lib/kodi/kodi.bin --standalone -fs --lircdev /var/run/lirc/lircd 2>&1 | logger -t xbmc"
else
su - pi -c "export APP_HOME=$(readlink /home/pi/.xbmc-current)'/xbmc-bin/share/kodi' ; /home/pi/.xbmc-current/xbmc-bin/lib/kodi/kodi.bin --standalone -fs --lircdev /var/run/lirc/lircd 2>&1 | logger -t xbmc"
fi
case "$?" in
# reattach fb
fi
DEPTH1=16
DEPTH1=8
DEPTH1=8
else
DEPTH1=8
DEPTH2=16
fi
start console-setup
fi
chvt 2
set -v
tput cnorm
tput setf 7
sleep 55
while true
do
break
fi
sleep 5
done
else
sleep 2
fi;;
set -v
tput cnorm
tput setf 7
sleep 60 ;;
sleep 2 ;;
66) # Reboot System
set -v
tput cnorm
tput setf 7
sleep 60 ;;
set -v
tput cnorm
tput setf 7
sleep 30 ;;
esac
done
That looks correct.
Don´t have many more suggestions... try to toggle the Remote switch in Raspbmc settings and reboot.
You are rebooting between switches, right? It might not be necessary, but in case it runs from memory it can fail (I think...).
To see of eventlircd is running:
ps aux | grep eventlircd
At work for next 9 hrs, so will check
tonight.
Yep, Rebooting between switching. Routine is
switch to kodi build
sudo sh enable-kodi.sh
rm .xbmc-current
ln -sfn /home/pi/.upgrade/kodi-14-20141103-nc4/xbmc-bcm /home/pi/.xbmc-current
sudo reboot
and back to pre-kodi build
sudo sh enable-xbmc.sh
rm .xbmc-current
ln -sfn /home/pi/.upgrade/kodi-14-20141019-nc4/xbmc-bcm /home/pi/.xbmc-current
sudo reboot
What I haven't tried, (I'm-a-dumb-ass), is
irw on the 20141019-nc4 build, to see if it runs. Will try that tonight.
Thanks again for your time.
irw works as it should in 20141019-nc4.
Wonder why it's not working in 20141103-nc4
Looking at those two watchdog.sh files, I see the biggest difference and stuff to do with lirc are
and
could this be the area that's causing issue with lirc?
Nope, that´s a necessary modification to be able to run Kodi on Raspbmc after the rebranding.
I see on the recent commits that this has changed yet again though so the scripts needs to be updated for a new build... but it is correct for the build you are trying to use now.
And it does work for me it seems, really don´t know what more to suggest.
Another thing, there are so many changes with the rebranding, and right now (since last build really, Nov 2 was fine) I seem to have big issues with my build root.
I tried to dig into this yesterday but gave up, I honestly don´t know what´s going on.
It doesn´t copy all binaries to .../xbmc-bin/lib/kodi/system, not even the plugins directory.
Even though it says "built successfully" it is complaining about a couple of libmmal files + libcontainer not being in place, but they are as far as I can see.
I have a config.log if someone is willing to dig into it, but right now I really feel that I would rather wait a bit to play around with OSMC beta!
After installing the latest build (kodi-14-20141103-nc4) airplay is now longer working. Was previously running build kodi-14-20141019-nc4 and there both video and audio airplay worked.
In the latest build no airplay destination is shown on my Apple devices (ranging from ios 5 to 8.1).
Is this a known problem?
(2014-11-04, 11:10)haegg78 Wrote: [ -> ]After installing the latest build (kodi-14-20141103-nc4) airplay is now longer working. Was previously running build kodi-14-20141019-nc4 and there both video and audio airplay worked.
No, but now it is, I had not noticed.
I see the problem, avahi does not start.
raspbmc dbus[249]: [system] Failed to activate service 'org.freedesktop.Avahi': timed out
You can start it manually with:
sudo avahi-daemon -D
I will see if I can figure out why that is, in the mean time start it manually or stick with the build from 19th of Oct.
Don't give up, happy to keep testing. (now I know how to switch back and forth)
(2014-11-04, 14:43)miappa Wrote: [ -> ]Code:
Check /etc/init/avahi-daemon.conf
start on (((started xbmc and enable-avahi-daemon) or no-xbmc) and started dbus)
stop on (stopping dbus or disable-avahi-daemon or runlevel [!2345])
Missing the change xbmc > kodi?
