2014-02-18, 13:33
@Bohlendach
Just set dvdplayer as default in advancedsettings.xml (see post#1)
This is optional and might be default in the future, but I let testers choose this themselves for now.
Updated Gotham build, XBMC master from Feb 18 + newclock3 commits.
Some info:
• NC3: Same as last build + fix for possible crashes
• Master: Fix for Ticket #14940
See last build for more info.
Firmware from 17th of Feb recommended.
Firmware update, recommendations and additional testing (DVDPlayer etc.), see post #1
To install XBMC build, SSH to Pi:
Activate new build in "Raspbmc Settings/Nightly…/Switch…”, choose new build + restart XBMC.
Some info:
cd .upgrade
wget -O xbmc-13-20140218-nc3.tar.gz http://goo.gl/NlU0zN --no-check-certificate
mkdir -p xbmc-13-20140218-nc3
pv xbmc-13-20140218-nc3.tar.gz | tar xzf - -C xbmc-13-20140218-nc3
cd xbmc-13-20140218-nc3/xbmc-bcm/xbmc-bin/lib/xbmc/system
cp /usr/local/lib/libdvdcss.so.2.1.0 .
ln -sf libdvdcss.so.2.1.0 libdvdcss.so.2
ln -sf libdvdcss.so.2 libdvdcss.so
