Updated Helix build,
Kodi/XBMC master from Aug 17 +
newclock4 commits.
NB! This is a more experimental build from popcornmix´s
newclock4 branch.
See explanation
here and
here.
GPU firmware from Aug 12 included
To install Kodi/XBMC build, SSH to Pi:
wget -O kodi-14-20140818-nc4.tar.gz http://goo.gl/u0A1LG --no-check-certificate
pv kodi-14-20140818-nc4.tar.gz | tar xzf - -C /home/pi/.upgrade
sudo cp /home/pi/.upgrade/kodi-14-20140818-nc4/{fixup_x.dat,start_x.elf} /boot
ln -sfn /home/pi/.upgrade/kodi-14-20140818-nc4/xbmc-bcm /home/pi/.xbmc-current
sudo reboot
See post #1 for more info (testing, different players etc)
Kodi/XBMC master from Aug 19 +
newclock3 commits.
Kodi/XBMC Master:
Master changelog
Newclock3:
• [dvdplayer] Allow UpdateCorrection to handle audio and video jumping asynchronously
• ADD: Freescale i.MX6 h/w codec
• ADD: [imx] native framebuffer support
GPU firmware from Aug 21 included:
See:
https://github.com/raspberrypi/firmware/...16ecdc9110
wget -O kodi-14-20140821-nc3.tar.gz http://goo.gl/gv0yRK --no-check-certificate
pv kodi-14-20140821-nc3.tar.gz | tar xzf - -C /home/pi/.upgrade
sudo cp /home/pi/.upgrade/kodi-14-20140821-nc3/{fixup_x.dat,start_x.elf} /boot
ln -sfn /home/pi/.upgrade/kodi-14-20140821-nc3/xbmc-bcm /home/pi/.xbmc-current
sudo reboot
Kodi/XBMC master from Aug 20 +
newclock4 commits.
newclock4 branch.
See explanation
here and
here.
wget -O kodi-14-20140821-nc4.tar.gz http://goo.gl/9EDTRd --no-check-certificate
pv kodi-14-20140821-nc4.tar.gz | tar xzf - -C /home/pi/.upgrade
sudo cp /home/pi/.upgrade/kodi-14-20140821-nc4/{fixup_x.dat,start_x.elf} /boot
ln -sfn /home/pi/.upgrade/kodi-14-20140821-nc4/xbmc-bcm /home/pi/.xbmc-current
sudo reboot
(2014-08-21, 20:48)miappa Wrote: [ -> ]Updated Helix build, Kodi/XBMC master from Aug 19 + newclock3 commits.
Kodi/XBMC Master:
• Master changelog
Newclock3:
See: https://github.com/raspberrypi/firmware/...16ecdc9110
sudo reboot
Going from xbmc-14-20140711-nc3 to this version broke PVR system. No clients could be enabled. I use MythTV. Going back to xbmc-14-20140711-nc3 worked fine. So system back up and working.
On boot up I got an error dialog saying not all add on data could be loaded and discovered that no LiveTV was available and I could not enable it.
Cheers
Spart
I had the same issue with the PVR Clients and have managed to resolve it, but it took a bit of fiddling around.
Recently there has been a bump of the minimum API version required for the PVR clients so you should see this line appear in the XBMC log file:
ERROR: PVR - Add-on 'Tvheadend HTSP Client' is using an incompatible API version. XBMC minimum API version = '1.9.1', add-on API version '1.9.0'
Putty into the PI and type the following to check: (it will be near the start of the log as its initialised when XBMC/Kodi first starts up)
vi ~/.xbmc/temp/xbmc.log
I can't remember where I read it somewhere, but the PVR Clients are not updated as part of the nightlies and only seem to be updated properly when RaspBMC is installed. It is however possible to get the latest pvr client source and compile them yourself - which is what i ended up doing. (Unfortunately I couldn't find any precompiled for use - not sure if it would work, but I could upload the zip for mythTV that I generated/compiled)
The Git Repo where the source is can be accessed here:
https://github.com/opdenkamp/xbmc-pvr-addons and the readme gives a guide on how to do the compiling. (On a PI it may take a little while)
If you compile them into zip files and then just install the addon from that zip, that worked for me. (Although i did delete all of the PVR Clients addons before i did this)
The source was updated about a month ago increasing the version number from 1.9.0 to 1.9.1, which makes it compatible again. The commit for this is here:
https://github.com/opdenkamp/xbmc-pvr-ad...2cb345f9c8
(Btw I am no where near an expert on Git, unix / linux etc - this was me just trying stuff and piecing things together)
I always compile latest PVR addons from Opdenkamps master tree (always latest PVR versions for latest Kodi/XBMC version), they are all included in the builds.
I don´t use PVR myself though so cannot test, however it sounds weird that you just compile the exact same versions to get it to work...(?).
(2014-08-22, 22:23)miappa Wrote: [ -> ]I always compile latest PVR addons from Opdenkamps master tree (always latest PVR versions for latest Kodi/XBMC version), they are all included in the builds.
They do not work in the nc3 build I used. PVR is disabled and I cannot re-enable it. Clearly the addons as still there as when I 'downgrade' back to the version I was running before, PVR works after I re-enable the mythtv addon.
Cheers
Spart
Ah, I found the problem regarding the PVR addons.
I have been using Sam´s scripts and he has changed the PVR build-script to use the Gotham branch.
This was done quite recently I guess, I will fix this for future builds.
Kodi/XBMC master from Aug 23 +
newclock3 commits.
Kodi/XBMC Master:
Master changelog
Newclock3:
• Same as last build
Extra commits:
• Fix for Helix PVR addons (previous build included Gotham versions which will not work)
wget -O kodi-14-20140823-nc3.tar.gz http://goo.gl/x7XZhQ --no-check-certificate
pv kodi-14-20140823-nc3.tar.gz | tar xzf - -C /home/pi/.upgrade
sudo cp /home/pi/.upgrade/kodi-14-20140823-nc3/{fixup_x.dat,start_x.elf} /boot
ln -sfn /home/pi/.upgrade/kodi-14-20140823-nc3/xbmc-bcm /home/pi/.xbmc-current
sudo reboot
newclock4 commits.
newclock4 branch.
See explanation
here and
here.
Extra commits:
wget -O kodi-14-20140823-nc4.tar.gz http://goo.gl/YpzlTX --no-check-certificate
pv kodi-14-20140823-nc4.tar.gz | tar xzf - -C /home/pi/.upgrade
sudo cp /home/pi/.upgrade/kodi-14-20140823-nc4/{fixup_x.dat,start_x.elf} /boot
ln -sfn /home/pi/.upgrade/kodi-14-20140823-nc4/xbmc-bcm /home/pi/.xbmc-current
sudo reboot
I just wanted to give an update to anybody who is curious about how good these builds word.
I just installed the build above and I could not believe how fast my RPi acted. It was responding like it my was ATV1 or something. I am not used to that kind of speed of the menus from any RPi I've ever touched.
Guys totally please keep up the great work on these builds. I'm able to better recommend RPi's to folks now that I don't have to tell them have a cup of coffee while using some add-on's LoL.
Kodi/XBMC master from Aug 25 +
newclock3 commits.
Kodi/XBMC Master:
Master changelog
Newclock3:
• [PiSink] Fix typo in list of passthrough samplerates (41.4 -> 44.1)
• [resamplepi] Support samplerates above 192kHz
wget -O kodi-14-20140825-nc3.tar.gz http://goo.gl/CavCts --no-check-certificate
pv kodi-14-20140825-nc3.tar.gz | tar xzf - -C /home/pi/.upgrade
sudo cp /home/pi/.upgrade/kodi-14-20140825-nc3/{fixup_x.dat,start_x.elf} /boot
ln -sfn /home/pi/.upgrade/kodi-14-20140825-nc3/xbmc-bcm /home/pi/.xbmc-current
sudo reboot
newclock4 commits.
newclock4 branch.
See explanation
here and
here.
wget -O kodi-14-20140825-nc4.tar.gz http://goo.gl/IAB6AI --no-check-certificate
pv kodi-14-20140825-nc4.tar.gz | tar xzf - -C /home/pi/.upgrade
sudo cp /home/pi/.upgrade/kodi-14-20140825-nc4/{fixup_x.dat,start_x.elf} /boot
ln -sfn /home/pi/.upgrade/kodi-14-20140825-nc4/xbmc-bcm /home/pi/.xbmc-current
sudo reboot
(2014-08-25, 20:33)miappa Wrote: [ -> ]Updated Helix build, Kodi/XBMC master from Aug 25 + newclock4 commits.
NB! This is a more experimental build from popcornmix´s newclock4 branch.
See explanation here and here.
sudo reboot
HiFiberry Digi not supported on this release, it's very noisy. It still hurt my hear.
and still problems for the cache any HD content suffer from that. It just can't work like that. The movies stop about 30 sec every 10 min. It's really anoying.
