Full Version: Need help how to set xbmc auto run
Hi everyone, I would like to get some input on how to setup the tv box to auto run xbmc when power on an off. Right now I have the box running android 4.2.2 and I manage to install this xbmc version xbmc-12.2-Frodo-armeabi-v7a.apk and so far the program is running fine. I have seen some mx box setup that is auto run xbmc when power on at my friend place and because I only want to use xbmc not android so is there a way to set up like that? I don't even know the right term for it but basically I just want xbmc and ignore the android Smile. So if you know how please help thanks.
nvm I found the solution and that is autostart app from android.
you can also install linux xbmc if yr box ix MX g18ref
thanks this will work with those box that can reset at power up like toothpick way.
