Full Version: Advanced Launcher Zip file
I'm trying to install angelscry to get Advanced Launcher. I've added the zip file location to my root folder. When I go to add on from zip, I can't see the zip file. I'm using the path http://www.gwenael.org/Repository/reposi...-1.2.2.zip
Is there a better or easier way to install this zip file with xbmcbuntu?
(2013-10-20, 20:15)Psubenny Wrote: [ -> ]I'm trying to install angelscry to get Advanced Launcher. I've added the zip file location to my root folder. When I go to add on from zip, I can't see the zip file. I'm using the path http://www.gwenael.org/Repository/reposi...-1.2.2.zip
You MUST see the zip file. Once you have downloaded the zip file you need to go into Systems > Add-ons > Install From ZIP file > Then, navigate to the place you saved the file and select it to install. If you still not able to see the zip file, so it means that you have not saved it or that you are are saved it in another place than you are looking for. Also, be sure that XBMC have the sufficient rights to acces the directory where you have saved the zip file.
How do you download a zip file in xbmc without a web browser?
You cannot. You need to download the zip file from another computer and then copy it on your XBMC system (using USB key for example) to be able to install it from XBMC.
