Hi to all!
I'm having a problem on my Linux HTPC after updating xbmc to latest rpm version, xbmc-12.2-3.fc18.x86_64:
[xefil@xefbmc ~]$
Running DIL (3.22.0) Version
DtsDeviceOpen: Opening HW in mode 0
DtsDeviceOpen: Create File Failed
/usr/bin/xbmc: line 137: 2366 Segmentation fault (core dumped) "$LIBDIR/xbmc/xbmc.bin" $SAVED_ARGS
which: no lsb_release in (/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/home/xefil/.local/bin:/home/xefil/bin)
Crash report available at /home/xefil/xbmc_crashlog-20131022_224758.log
Crash log here:
Any idea?
thank's!
Simon
don't put logs on the forum
use pastebin.com
(2013-10-22, 22:56)Martijn Wrote: [ -> ]don't put logs on the forum
use pastebin.com
Sorry, I'll do so.
(2013-10-22, 22:53)fritsch Wrote: [ -> ]Try to run:
I'm not at home right now, but sending the command to my display at home should enough to check your commands...
Here the output:
[xefil@xefbmc ~]$ export DISPLAY=:0
[xefil@xefbmc ~]$ AE_ENGINE=Soft xbmc
/bin/xbmc: line 137: 1594 Segmentation fault (core dumped) "$LIBDIR/xbmc/xbmc.bin" $SAVED_ARGS
which: no lsb_release in (/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/xefil/.local/bin:/home/xefil/bin)
Crash report available at /home/xefil/xbmc_crashlog-20131023_102500.log
Crash log here:
http://pastebin.com/jBepmz5d
I've seen an ERROR on "ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer"
Don't know if it's the issue or it's to problem related to sending the command to external display, but should work as well.
Thank's for the help!
Simon
enable debugging.
xbmc --debug
or via advancedsettings.xml
(2013-10-23, 11:32)wsnipex Wrote: [ -> ]enable debugging.
xbmc --debug
Here the output:
[xefil@xefbmc ~]$ xbmc --debug
/bin/xbmc: line 137: 2228 Segmentation fault (core dumped) "$LIBDIR/xbmc/xbmc.bin" $SAVED_ARGS
Crash report available at /home/xefil/xbmc_crashlog-20131023_114348.log
And here the crash log:
http://pastebin.com/VLyLrDGW
Cannot find helpful informations...
Simon
nothing really useful in there, only thing that comes to mind could be a too old libcec
A 'yum update' of the whole system has solved the issues!
Thanks to all!
Simon
