Full Version: Skin.setString()
Is there any way to change the "enter the new label" when using Skin.setString().
I have searched and the only way was via the forked mediaportal, I feel that i may be missing something simple.
Sorry if it's obvious.
nah, not possible.
You would need something like this In DialogKeyboard.xml:
PHP Code:
<control type="label" id="311">
description>Dialog Header</description>
visible>!StringCompare(Control.GetLabel(311),$LOCALIZE[1029])</visible>
control>
control type="label">
description>Dialog Header (SetString)</description>
visible>StringCompare(Control.GetLabel(311),$LOCALIZE[1029])</visible>
label>Your custom label</label>
control
