Full Version: Maverick
Pages: 1 2 3 4 5
After upgrading OS X to version 10.9 Mavericks DP 1, I'm experiencing problems with starting XBMC.
When starting XBMC it bounces one time in the dock before disappearing.
I have not tried deleting config/userdata files yet, as I would prefer fixing it without being forced to set up everything again.
Does anybody have experiences running XBMC on OS X 10.9 ?
Logfile
17:08:06 T:140735239856912  NOTICE: -----------------------------------------------------------------------
17:08:06 T:140735239856912  NOTICE: Starting XBMC (12.2 Git:20130502-32b1a5e), Platform: Darwin OSX (13.0.0 x86_64, Version 10.9 (Build 13A476u)). Built on May  2 2013
17:08:06 T:140735239856912  NOTICE: special://xbmc/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
17:08:06 T:140735239856912  NOTICE: special://xbmcbin/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
17:08:06 T:140735239856912  NOTICE: special://masterprofile/ is mapped to: /Users/Vebjorn/Library/Application Support/XBMC/userdata
17:08:06 T:140735239856912  NOTICE: special://home/ is mapped to: /Users/Vebjorn/Library/Application Support/XBMC
17:08:06 T:140735239856912  NOTICE: special://temp/ is mapped to: /Users/Vebjorn/.xbmc/temp
17:08:06 T:140735239856912  NOTICE: special://frameworks/ is mapped to: /Applications/XBMC.app/Contents/Frameworks
17:08:06 T:140735239856912  NOTICE: The executable running is: /Applications/XBMC.app/Contents/MacOS/XBMC
17:08:06 T:140735239856912  NOTICE: Local hostname: VKmbp13.local
17:08:06 T:140735239856912  NOTICE: Log File is located: /Users/Vebjorn/Library/Logs/xbmc.log
17:08:06 T:140735239856912  NOTICE: load settings...
17:08:06 T:140735239856912   ERROR: Unable to load libcrystalhd.dylib, reason: dlopen(libcrystalhd.dylib, 1): image not found
17:08:06 T:140735239856912  NOTICE: special://profile/ is mapped to: special://masterprofile/
17:08:06 T:140735239856912  NOTICE: loading special://masterprofile/guisettings.xml
17:08:06 T:140735239856912  NOTICE: Getting hardware information now...
17:08:06 T:140735239856912  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:08:06 T:140735239856912  NOTICE: Loaded playercorefactory configuration
17:08:06 T:140735239856912  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:08:06 T:140735239856912  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:08:06 T:140735239856912  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
17:08:06 T:140735239856912  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
17:08:06 T:140735239856912  NOTICE: Default DVD Player: dvdplayer
17:08:06 T:140735239856912  NOTICE: Default Video Player: dvdplayer
17:08:06 T:140735239856912  NOTICE: Default Audio Player: paplayer
17:08:06 T:140735239856912  NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:08:06 T:140735239856912  NOTICE: Log level changed to 0
17:08:06 T:140735239856912  NOTICE: Loading media sources from special://masterprofile/sources.xml
[/code]
removed151214
Looks like it could be another problem with audio.
18:15:57 T:140735178355472   DEBUG: CCoreAudioHardware::FindAudioDevice: Returning default device [0x002f].
18:15:57 T:140735178355472   ERROR: CCoreAudioDevice::SupportsMixing: Device mixing support : 'No'.
18:15:57 T:140735178355472   DEBUG: CCoreAudioGraph::CreateMixMap: Source Stream Layout: [Left] [Right]
18:15:57 T:140735178355472   DEBUG: CCoreAudioGraph::CreateMixMap: User-Configured Speaker Layout: [Left] [Right]
18:15:57 T:140735178355472   DEBUG: CCoreAudioGraph::CreateMixMap: Output Device Layout: [Left] [Right]
18:15:57 T:140735178355472   ERROR: CCoreAudioUnit::SetFormat: Unable to set AudioUnit format. Bus : 0 Scope : 1 : Error = -10868
18:15:57 T:140735178355472   DEBUG: CCoreAudioAEHALOSX::Initialize: Unable to initialize audio due a missconfiguration. Try 2.0 speaker configuration.
18:15:57 T:140735178355472    INFO: CCoreAudioAE::Initialize:
18:15:57 T:140735178355472    INFO:   Output Device : default
18:15:57 T:140735178355472    INFO:   Sample Rate   : 44100
18:15:57 T:140735178355472    INFO:   Sample Format : AE_FMT_FLOAT
18:15:57 T:140735178355472    INFO:   Channel Count : 2
18:15:57 T:140735178355472    INFO:   Channel Layout: FL,FR
18:15:57 T:140735178355472    INFO:   Frame Size    : 8
18:15:57 T:140735178355472    INFO:   Volume Level  : 1.000000
18:15:57 T:140735178355472    INFO:   Passthrough   : 0
18:15:57 T:140735178355472   FATAL: CApplication::Create: Failed to start the AudioEngine
18:15:57 T:140735178355472   DEBUG: PVRManager - destroyed
18:15:57 T:140735178355472   DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
Eden works fine on Mavericks, but Frodo (tried 12.0 and 12.2) and Gotham nightlies won't launch, showing the same in their logs.
Just fyi - we don't care about mavericks until its released. That was like that for all other plaforms and will stay that way in the future aswell.
With all respect Memphiz, shouldn't XBMC be ready for Maverick (in the development branch) before it's released and not start patching it when thousands of users update when the final build is out?
(2013-06-17, 13:49)tripkip Wrote: [ -> ]With all respect Memphiz, shouldn't XBMC be ready for Maverick (in the development branch) before it's released and not start patching it when thousands of users update when the final build is out?
Do you seriously think they're going to do that? No dev is scrambling on Mavericks crashes right now because the dev preview is so painfully unfinished that you can't tell if it's the OS's fault or the application's fault. The only thing of interest right now are new APIs and the like.
Even when it's time to really start working on it, some (one?) of our OS X devs are registered OS X devs, so they're under an NDA like everyone else who's using a dev preview. If they weren't, it still wouldn't matter because by the time 10.9 is released, XBMC v13 still won't be done, so there will be time to fix any major issues.
We're not even close to the part where user reported bugs are helpful. Right now that stuff is just noise.
I am not an registered OSX dev. And you can't assume that anybody of the team is. So at least i am not even able to fetch the preview. And no - it is the thing of the user to jump on new trains. I don't play that game - we never did. Sue me.
removed151214
Want to thank the developers for being so clear Smile
I'm happy to add my experiences of running XBMC on developer previews of OS X primarily as a warning to those - and you know who you are Wink - who aren't willing to wait for the final release of OS X before installing it on a regularly used machine and expecting it to work. XBMC doesn't work, and don't expect it to before Mavericks is finally released.
And to reiterate what the developers have said, at this stage it's nothing to do with the XBMC developers as to whether it runs or not. I have to be a little careful with what I say as I'm under an NDA with Apple, but I think its fair to say that every update of OS X brings changes to key systems and API's which break compatibility with existing apps. And those systems and API's are going to continue to change throughout any developer preview Apple chooses to do. It's not until those are finalised - which will happen at the GM stage (or later, if more than one GM is needed) that the developers of XBMC should even start to concern themselves with compatibility with the new version.
At this stage, the people to bug about XBMC not working are Apple themselves - and then, only if you're a registered developer. Go tell them they've broken compatibility with the app. I have! Hope for them to fix it before final release and, if they don't, don't even consider asking for the XBMC developers to consider fixing it until GM.
And, if you're not a registered developer then simply don't use the DP and don't worry about compatibility at all - there's nothing you can do at this stage, and nothing the XBMC developers will do (or that it would even be sensible for them to do) about it at this stage.
Thx - nice sum up. For the boys in the back which can compile on their own - here is a proposed fix for 10.9 DP:
https://github.com/xbmc/xbmc/pull/2891
Hi and thanks for the solution, anyone have the builded .app ? I m testing Maverick on my Air and I haven't Xcode on this device I have to wait until the weekend to compile it on my iMac :'(
Just compiled that fix, it works on OSX 10.9 DP1 (and also still works on 10.8 ;-) ). Needs to be compiled on a 10.8 machine, since the build system isn't yet modified for the new XCode versions.
The fix will probably appear soon in the nightly builds.
Tx for the quick solution!
Is it possible to link to a compiled version of this app also? I don't have a 10.8 machine handy to build this with.
Then what are you guys doing with a DEVELOPER preview?
latest nightly has it ...
(2013-06-21, 08:19)ae86nate Wrote: [ -> ]*** edit: no need to quote ***
We try to keep a healthy atmosphere on these forums. You are free to dislike someone but please refrain from calling names.
Why not behave like an adult and explain what your problem is ?
It might not be the way you do stuff in Spanaway - it sure is how we deal with issues in the rest of the world.
I'd love to be able to compile a 12.2 build with this patch (without having to resort to a nightly, which will change DB version and require me to update all my clients) but I can't get the latest Xcode to play nice.
Pages: 1 2 3 4 5
