Full Version: Problem hiding text
Wanted to hide parts of text / dialogs when other dialogs were open but:
SkinSettings.xml doesn't seem to notice that DialogSelect.xml is opened.
DialogFavorites.xml doesn't seem to notice that FileBrowser.xml is opened.
Tried numbers and names, code working in other windows.
using <visible>!Window.IsVisible(selectdialog)</visible> in skinsettings works for me
and <visible>!Window.IsVisible(filebrowser)</visible> in dialogfavourites works as well on my end
I've had to use this instead before -
Window.IsActive(DialogSelect.xml)
SkinSettings.xml does respond to:
Skin.SetAddon(addon.subtitles.path,xbmc.python.subtitles)
But not to:
RunScript(script.favourites,property=CustomFavourite1)
This is fixed by using Window.IsActive(DialogSelect.xml) as Hitcher suggested.
DialogFavorites.xml is also solved, I needed an extra group enclosing everything.
Thnx Smile
The favourites script uses DialogSelect.xml as it's xml base class but it doesn't actually open a select dialog. That's why Window.IsActive(selectdialog) doesn't work and you have to use Window.IsActive(DialogSelect.xml).
