Full Version: XBMC v12.2 crashing on OS X 10.9 Mavericks
Pages: 1 2 3 4 5 6 7 8 9
(2014-02-03, 05:27)DruBoy Wrote: [ -> ]I've dl the new xbmc version but mavericks is still not letting it run. it says "XBMC" can't be opened because it is from an unidentified developer. Help please
HOW-TO:Install_XBMC_for_Mac#Gatekeeper (wiki)
Quote:Right click (or command+click) the XBMC icon and select "open"
DruBoy http://lmgtfy.com/?q=can%27t+be+opened+b...+developer just google it its simple! it has nothing to do with the xbmc
Hello, I got the same problem. When I open XBMC ( OSX x86-64 & nightly ) it crashes on opening.
I think it has something to do with the Add-on I added like 4 months ago, after that I stopped using XBMC and removed it from my Macbook Pro.
I've been searching the internet for the solution. But so far, I have not yet find it.
Does somebody have the same problem as me? And if so, can someone tell me how to solve this problem?
Crashed Thread: 20 PVR add-on updater
Thread 20 Crashed:: PVR add-on updater
0 libsystem_platform.dylib 0x00007fff8dbb9e34 _os_lock_corruption_abort + 0
1 libsystem_platform.dylib 0x00007fff8dbb9e34 _OSSpinLockLockSlow + 125
2 libsystem_pthread.dylib 0x00007fff93ec2a41 pthread_mutex_destroy + 25
3 libcec.2.dylib 0x000000010ad17af6 PLATFORM::CMutex::~CMutex() + 30
4 libcec.2.dylib 0x000000010ad08296 PLATFORM::CThread::~CThread() + 184
5 XBMC_dvbviewer.pvr 0x000000011097b5df Dvb::~Dvb() + 831
6 XBMC_dvbviewer.pvr 0x00000001109773d6 ADDON_Create + 422
7 com.teamxbmc.xbmc 0x000000010077af01 ADDON::CAddonDll<DllPVRClient, PVRClient, PVR_PROPERTIES>::Create() + 181
8 com.teamxbmc.xbmc 0x000000010077852e PVR::CPVRClient::Create(int) + 114
9 com.teamxbmc.xbmc 0x000000010078408a PVR::CPVRClients::UpdateAndInitialiseClients(bool) + 2398
10 com.teamxbmc.xbmc 0x000000010078480a PVR::CPVRClients:Tonguerocess() + 108
11 com.teamxbmc.xbmc 0x00000001003904ce CThread::Action() + 156
12 com.teamxbmc.xbmc 0x0000000100390d5d CThread:ConfusedtaticThread(void*) + 263
13 libsystem_pthread.dylib 0x00007fff93ebf899 _pthread_body + 138
14 libsystem_pthread.dylib 0x00007fff93ebf72a _pthread_start + 137
15 libsystem_pthread.dylib 0x00007fff93ec3fc9 thread_start + 13
rm /Users/<yourusername>/Library/Application Support/XBMC/userdate/guisettings.xml - this will clear your settings. The crash is because livetv support (do you use it at all?)
Thanks mate! It worked, it now works as it should be. Thank you for the help. Greetings from the Netherlands.
i can't even open xbmc it keeps giving this message I've deleted it and redownloaded it help please
http://pastebin.com/ruvsLsRS
edit by memphiz: moved crashlog to pastebin.com
can you reproduce the same crash when using a nightly build? (e.x. http://mirrors.xbmc.org/nightlies/osx/i3...r-i386.dmg)?
yea every time i try to open it same error
Hi All very to day to this. I installed XBMC on my macbook this morning all was looking good then my macbook said i had a update so I proceded with the update to OSX 10.9.1 and since then it will not load xvmc says its from a unknown sour or provider have i got to update something else i have up dated the the mirror site to 12.3 but still the same I hope someone can help me. many thanks in advance
I've done everything still can't get it to open every time it asks if i want to reopen it i can hit ok or reopen and still gives me the same error message Application Specific Information:
*** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'Error (1007) creating CGSWindow on line 263'
i had it running solid for few months i don't understand it
And you are the only person here i have seen with this problem. There is not much i can tell you here cause i can't reproduce it nor can i even imagine what is wrong with your constellation. Sad
Gents,
I have the same issue as ajames 48, this started today. No updates that's I'm aware of, suddenly xbmc started crashing to the point where now as soon as I open mashup addon, the crash happens.
I'm using macbook pro retina
os 10.9.1
XBMC 12.3
I cannot post the log here as it exceeds the character count.
YJ
pastebin.com and put the link in here. as mentioned in debug log (wiki) ...
I am having the same problem with it crashing as soon as i try to open it. Cant seem to get it going tried redownloading and still doing the same unexpected exit. any help is appreciated.
Solution as follows -
Ok heres what to do first go to this site and download apptrapp i run it on all my Macs http://onnati.net/apptrap/
Next delete XBMC drag it over to trash app trap will ask to delete all click ok.
Now go here http://xbmc.org/download/ make sure to download OSX version "Not the OSX x86-64"
MOD EDIT: REMOVED PIRACY LINK. BE WARNED
Solution from Rockcrusher.
This solved it for me.
YJ
