2014-02-27, 03:58
2014-03-07, 00:15
@ajames48 - i am unsure what you did to fix it ... but can you revert it and see if this build also fixes your crash? That would be a big help because nobody of us can reproduce the crash but it was reported a second time here:
http://forum.xbmc.org/showthread.php?tid=187355
Please test this build:
http://mirrors.xbmc.org/test-builds/osx/...x86_64.dmg
2014-03-22, 14:15
Unfortunately, XBMC has basically become unusable for me. It crashes almost every time I try to play a .mkv file... I've tried 12.2, 12.3 the 13 betas, a whole bunch of nightly builds, the fixes in this thread, disabling hardware decoding... I'm desperate and begging for help...
Here's the most recent crash log... http://pastebin.com/vPRuzwkL
I use a 2012 Mac Mini and OS X 10.9.2. My sound card is a Metric Halo 2882 and my display is a 27" Thunderbolt display... if that makes any difference whatsoever?
2014-03-28, 20:49
Howdy, y'all. I've read much of this thread and have a similar issue, in that XBMC is unstable for me under Mavericks, 10.9.2. In fact, it was working for a bit, but I believe that switching between Window and Full-Screen mode is what has caused it to crash every time it runs now. I believe it did not like being windowed.
Error report posted: http://pastebin.com/YGVVadmu
I've updated to 14 alpha 1 as suggested in this thread, also to 12.3, and checked last night's daily build.. No luck. I've removed the user folder as well in ~/Library/Application Support.
Any help would be appreciated! Thanks!
2014-03-29, 00:33
This: http://pastebin.com/UYDMfbFJ
is from attempting to start XBMC 14 alpha 1. As mentioned, they all crash on me though. Thanks!
2014-03-29, 00:39
You have configured XBMC for using "iMic USB audio system" . The driver of that soundcard is broken and reports only "0hz" as supported sample rate. Your crash will be fixed in Gotham beta3 which should be out in a couple of days.
2014-03-29, 01:13
Thank you! You all are the best! I've been using XBMC since Xbox1 and greatly appreciate your work!
Unfortunately for me, this is what I get when I unplug the iMic USB and run XBMC 14.0 alpha.
Crash report: http://pastebin.com/ZQyKyiBU
XBMC log: http://pastebin.com/C02KJrc9
Any help is, again, appreciated.
2014-03-30, 23:41
Ahhh nice - now you hit another issue which was reported by only 2 other users. Both didn't respond to my test build. Please continue here:
http://forum.xbmc.org/showthread.php?tid=187355 and try the testbuild there and report back if it fixes that crash.
2014-03-31, 00:52
Still getting the old kaibosh!! But, here's the logs:
http://pastebin.com/fUc3xC7x - Apple Error Report
http://pastebin.com/Rf5anGVR - XBMC.log
Looking forward to your response! Thanks!
2014-03-31, 15:36
Please try to change the setting in osx Settings->Displays->Resolution (try "scaled" or "best for display" and see if it makes a difference to that crash).
Also in addition please try this test build and post a new debug log (wiki) (it won't fix the crash - but adds a printout in the log file which is important to me).
2014-03-31, 16:11
It was already on Best for Display. I changed it to Scaled and nothing appears to have changed.
Logs: http://pastebin.com/UktxXhfe (Apple) & http://pastebin.com/39zfcPP2 (XBMC)
Test build logs (display at scaled):
Apple - http://pastebin.com/jWL3WP8T & XBMC - http://pastebin.com/nwb3gRa7
Test build logs (Best for Display setting):
Apple - http://pastebin.com/BJBWjkkU & XBMC - http://pastebin.com/p2MLMqTJ
Thanks! Looking forward to hearing back from you. Be well!
2014-03-31, 16:52
Can you please attach your guisettings.xml file to be found in your userdata (wiki) folder
2014-03-31, 18:28
2014-03-31, 21:06
Search for "<width>616192</width>" in that file and replace it with somthing sane - e.x. 1200 or so - save the file and start again. Any idea how this strange window width was generated?
