Full Version: Frustrated beyond belief.
Vimeo, 1Channel Script failed. I've spent days on this trying to get xbmc to function.. at the end of the rope, please help.
http://pastebin.ubuntu.com/6301972/
If you can, get screenshots to illustrate problems (See below) Simply says Script failed at the top of the screen in a box.
"Latest" is NOT a revision, of ANYTHING! (See below) Raspbmc running xbmc 12.2 git:20130502-32b1a5e
Linux Distribution and Version (See below) 3.10.15 #2PREEMPT WEd Oct 9 22:53:53 UTC 2013 armv6l
Architecture (e.g.. i686, x86_64, etc. (See below) RUnning on a Raspberry Pi ver. 2
Install Method (PPA, RPM, build.sh, manual, other) Raspmbc installer
GIT Revision (See below.) above
Detailed Instructions to Reproduce the Problem (The more specific the better.) Just trying to view a video in Vimeo or 1channle produces script failed. I reverted back to an image of the same system from two weeks ago, was able to watch half an episode until the scrit failed message displayed again.
Backtrace (Only attainable if XBMC has crashed. See below.) does not crash.
Compiler Output (Only useful if XBMC doesn't build. See below.)
EDIT: Also happens on other raspbmc releases.
Welcome to the XBMC forums.
We won't help you with 1Channel (see here: http://forum.xbmc.org/showthread.php?tid=149712 )
For Vimeo, the add-on appears to be broken. Check the latest posts in the thread devoted to this add-on: http://forum.xbmc.org/showthread.php?tid=81052
To rule out a general problem with video add-ons, try another (non-piracy) one such as YouTube to see if it works for you.
(2013-10-25, 21:19)artrafael Wrote: [ -> ]Welcome to the XBMC forums.
I should have figured that, sorry. I had read that thread on Vimeo.. It was working after all of those posts were posted however.. and then now just stopped working. And If I restore my previous image from two weeks ago, it works again.. so something changes in the process of using it to cause it to stop.
