Full Version: tvshow spontaneously disappears
And cannot be scanned back in. XBMC refuses to see a newly added season, and instead removes the series from the library. Filenames are correct, folders are correct. This used to work fine. Now it just stops, on adding a new season folder. I can browse and play the files just fine. What could be the issue here?
I'd guess it's the same problem as discussed here: http://forum.xbmc.org/showthread.php?tid=176082 and here http://trac.xbmc.org/ticket/14646 if you're on sqlite-3.8.1
