Hi folks,
activated timeshift on demand when hitting pause .. seems to work, but when playing on, it stops always after about 2-5 minutes ..
Greetz
Lastcoder
Have you check the box Unlimited Max File Size ?
Max. Period & Max. Size set to "unlimited" ..
no one else with that error ?
Btw. is there any activity on tvheadend development ?
I can't comment on your problem (I don't use timeshift), but definitely "yes" to the second question. The DVB subsystem has been completely re-written and was recently committed back to the master branch, and there are many ongoing changes to other parts of the software as well.
https://tvheadend.org/projects/tvheadend/repository
Last commit was yesterday, if that's active enough for you ;-)
has anyone brought tvheadend timrshift to work?
(2013-12-25, 16:58)tom1502 Wrote: [ -> ]has anyone brought tvheadend timrshift to work?
Last time i used it, it worked perfect. I'm on build 3.4.x
Do You have a synology backend?
Perfect
what Timeshifting path dif you configure?
(2013-12-25, 18:43)tom1502 Wrote: [ -> ]Perfect what Timeshifting path dif you configure?
I created a timeshift folder in recordings folder.
/volume1/recordings/timeshift
Edit:
I tried latest 3.9.x version but that didn't return channel tags so i reverted back to 3.4 from synocommunity.
Ok, guess that's the issue. Will try that out once I am at home.
Thank you!!!
Ok, i'Ve now created a folder in /volume1/videos/... (which is my main directory for videos) and timshifting now seems to work after a first quick test. Thank you very much!!!
(2013-12-25, 20:45)tom1502 Wrote: [ -> ]Ok, i'Ve now created a folder in /volume1/videos/... (which is my main directory for videos) and timshifting now seems to work after a first quick test. Thank you very much!!!
Looks like a rights issue then, glad it's solved.
Happy holidays
