(2013-11-26, 16:19)Mangoes Wrote: [ -> ]I just tested the new nightly, which includes the commit with lmyllari's fix.
http://xbmcnightlybuilds.com/openelec-ge...-download/
It seems to me that the blacks are too grey, I remember the lmyllari build to be better than this.
It needs more testing. Could anyone of you please try it out and report with your findings?
edit: with no xrandr line in autostart.sh, limited range off in xbmc settings
edit 2: ah, it seems there's another commit that missed this build "i915: Fix Full Limited conversion ".
I've also tested last build OpenELEC-Generic.x86_64-devel-20131126081257-r16438, xrandr autoexec disabled and blacks are not black, just grey even when 16-235 range is set.
But there is strange behavior eather: Please select first Color range 16-235, then below reset settings to default - not the screen are darken and color range is unselected; Then check Colour range 16-235 - the screen are brighter, then unselect this setting - wow, the screen is even brighter There is some bug I suppose.
(2013-11-26, 19:23)Mangoes Wrote: [ -> ] (2013-11-26, 18:58)gamble Wrote: [ -> ]And i decided that ill stick with the stable Build for now, i´m fed up of running from one problem into another
Only thing tempting would if lmyllari ups a patched stable Version
Actually, I see the stable build to be having more issues than the nightlies. Broken FLAC 6.1, broken forced subtitles switching,...
The nightlies fix these issues and work fine enough for me. All in all its a much better experience than the stable build as the things I need finally work. Just stick to the builds that fix the colors / black levels, and set the xbmc gui refresh rate to 23.98 for HD audio passthrough (playback can still be set to match the source video, doesn't matter).
I tried all the Nightlies since page 46 of this Thread and yeah things do get better but im tired of sitting 1-2 hours a day between the forums and the NUC triing to figure out the next step without getting stuck into a random Problem again...maybe on the weekend again when i have more spare time, but now after work i am totally NOT in the right mood
(2013-11-26, 19:36)Ravetrancer Wrote: [ -> ] (2013-11-26, 18:58)gamble Wrote: [ -> ]For now i can shut off even while playing a movie and it stays off so i can't try
What build do u use?
Did you do a autostart.sh?
Any advancedsettings?
Latest Frodo on OpenElec 3.2.3
Yes, autostart.sh with xandr for full range RGB, no IR cuz i only use my ipad to control it.
No advanced settings
(2013-11-26, 19:57)IBTB Wrote: [ -> ]I am however still not satisfied with the video. Don't know exactly how to set a word on it, but it's just like the video stutters a little bit (very little) and I have compared the same source (I notice it good on the intro in Disney movies) on other (physical) players I feel the picture is "floating" better than on the NUC.
Yeah, i kinda feel the same for micro stuttering, never compared it to another device and in the beginning i thought it would be the 24p look..but i do know what u mean.
The hit-stop-before-shutdown trick does work, confirmed here also. Have no idea why that would make any difference because XBMC is shutdown anyway.
https://www.dropbox.com/s/99thzttxxdm9uo...r16441.tar is the build I'm using. It's based on the latest master, and adds my limited 16..235 passthrough hack. Remove any xrandr commands and don't use 16-235 in xbmc settings unless you know exactly what you're doing -> blacks and colors should work fine.
I'll upload a 3.2 based build too with the fixes in a few hours.
(2013-11-26, 20:22)arokh Wrote: [ -> ]The hit-stop-before-shutdown trick does work, confirmed here also. Have no idea why that would make any difference because XBMC is shutdown anyway.
So you pressed stop 1 extra time and it shut down like it should do right?
Want to know because i sat for hours yesterday starting and shutting down the nucs to see when it worked and when it didnt work.
(2013-11-26, 21:29)lmyllari Wrote: [ -> ]https://www.dropbox.com/s/99thzttxxdm9uo...r16441.tar is the build I'm using. It's based on the latest master, and adds my limited 16..235 passthrough hack. Remove any xrandr commands and don't use 16-235 in xbmc settings unless you know exactly what you're doing -> blacks and colors should work fine.
lmyllari, my hero
(2013-11-26, 19:57)IBTB Wrote: [ -> ]My config (Running Frodo 12.2):
Settings - Videos:
- Render method: DXVA (tried with Pixel Shaders and Software, but found DXVA to be best).
- Allow hardware acceleration (DXVA2): On
- Adjust display refresh rate to match video: Off
- Sync playback to display: Off
Settings - System - Video output:
- Display Mode: Full Screen #1
- Resolution: 1920x1080p
- Use a fullscreen window rather than true fullscreen: Off
- Vertical blank sync: Always enabled
I have tried changing one and one parameter, but I still can't get a "perfect" picture.
I tried pressing "o" to see fps output and CPU load during my different settings, but neighter try (even tho some settings gave very clearly stutters) showed any drop in fps output or CPU load over 10%.
If anyone got any tips, I'd be grateful!
Unless you have a lousy TV that doesn't support 24p (or 48p), always set:
ON
There should be no stuttering with this.
If i set the Adjust display refresh rate to match, Sound doenst work anymore..
Thats a bug with the latest linux kernals, try a different refresh rate such as 50hz
(2013-11-26, 22:37)gamble Wrote: [ -> ]If i set the Adjust display refresh rate to match, Sound doenst work anymore..
Which build? Stable? I never had this during the 2 years I have been using XBMC.
Adjust display refresh rate to match should always be set to match to keep a smooth playback without stuttering.
But with the gotham builds the xbmc gui refresh rate should be set to 23.98, otherwise passthrough doesn't work (and keep "Adjust display refresh rate to match", it will switch automatically and the sound passthrough will still work).
edit: ah zag was a couple seconds faster, yea so if there's a bug.... but still, works fine for me.
edit 2: and keep in mind that if Adjust display refresh rate to match is not ON, it is practically not possible to have smooth playback. This is the only way to avoid lost frames, unless you have a TV with very high refresh rates that can extrapolate to match.
(2013-11-26, 22:41)zag Wrote: [ -> ]Thats a bug with the latest linux kernals, try a different refresh rate such as 50hz
Do you have any more information on this?
Using OpenELEC-Generic.x86_64-devel-20131126081257-r16438 NUC is power off every time, from remote and from GUI, S4/S5 disabled in BIOS, something was improved.
(2013-11-26, 22:54)mstef Wrote: [ -> ]Using OpenELEC-Generic.x86_64-devel-20131126081257-r16438 NUC is power off every time, from remote and from GUI, S4/S5 disabled in BIOS, something was improved.
Maybe the update to kernel 3.12.1?
(2013-11-26, 23:05)zag Wrote: [ -> ]http://openelec.tv/forum/68-audio/67227-...m-at-1080p
Read my post #17
Thanks. Looks like that patch hasn't made it to 3.2 branch.
Maybe I should pass on the 3.2 build - there will be issues like this with it. Haswell seems to need recent bits, and more recent patches on top of that.
You can try, we can test, please.
I have the following settings (Win 8.1, i3 NUC, Frodo 12.2):
My config:
Settings - Videos:
- Render method: Auto Detect
- Adjust display refresh rate to match video: On
- Use a fullscreen window rather than true fullscreen: On
Seems to work fine. I'll admit I'm more of a casual user though, so don't know if these are considered the 'right' settings....if anyone more knowledgeable than me thinks I should be using something different then I'm happy to change and feedback the results.
