Full Version: Intel NUC - Haswell (4th Generation CPU)
(2013-12-02, 08:06)lmyllari Wrote: [ -> ]My resources is as follows (and IR works):
i5-nuc:~ # cat /sys/devices/pnp0/00\:08/resources
state = disabled
io 0x240-0x24f
irq 3
io 0x250-0x25f
Thank you! Is there a similar way to make the front analog audio connection work?
(2013-11-29, 19:12)BLKMGK Wrote: [ -> ]
(2013-11-29, 13:32)Peppin Wrote: [ -> ]
(2013-11-29, 12:28)arokh Wrote: [ -> ]Guys, let's not turn this into a general XBMC/OpenELEC support thread? At least use the search button..
I've (kinda) read every page and searched through it...I thought this would be the right place because the NUC IR is specifically related to this topic right? Anyway got your PM, thank you very much for guiding direction.
Still, I wonder I should she something related to remote control @ XBMC input settings. Im not sure how else to test whether my CIR is working correctly.
OE is using lirc for the remote control support. The command irw at a shell prompt should show you what it's receiving from a remote. I've confirmed this will display commands from my MCE remote just fine and I'd expect will at least let you know if commands are being received.
(2013-11-29, 19:09)Acrobat76 Wrote: [ -> ]Europeans:
Looking to buy the i5 NUC. Any sightings on websites which ship europewide? (e.g. overclockers, digitalo.de, amazon etc)
Watch Amazon, be prepared to overpay. I had one in my basket at a reasonable cost and by the time I was ready to push the button it was removed from sale! If you buy from Amazon directly it's backordered but they will ship when in stock and if the price drops give you the savings. I ended up with an i3 model and so far so good though when I eventually buy a second it will almost certainly be i5 for the added power\peace of mind.
Thanks will try that when I get home.
Did any of you compile a r16441 build with Frodo 12.2 (due to subtitle addon)?
(2013-12-02, 16:30)Peppin Wrote: [ -> ]
(2013-11-29, 13:32)Peppin Wrote: [ -> ]I've (kinda) read every page and searched through it...I thought this would be the right place because the NUC IR is specifically related to this topic right? Anyway got your PM, thank you very much for guiding direction.
http://forum.xbmc.org/showthread.php?tid...pid1560360 - this is the last published 12.x version on this forum/thread.
(2013-12-02, 16:35)mstef Wrote: [ -> ]
(2013-11-29, 19:12)BLKMGK Wrote: [ -> ]OE is using lirc for the remote control support. The command irw at a shell prompt should show you what it's receiving from a remote. I've confirmed this will display commands from my MCE remote just fine and I'd expect will at least let you know if commands are being received.
Ah ok thanks, will give that a try. Should I follow these steps? http://wiki.openelec.tv/index.php?title=...owngrading
Tranquil has 20% off their fanless chassis for cyber monday
http://www.tranquilpcshop.co.uk/nuc-next...s-haswell/
Tempted but VAT still makes it £100, and some competitors still have yet to reveal everything (e.g. NC3)
(2013-12-02, 16:39)Peppin Wrote: [ -> ]
(2013-12-02, 16:30)Peppin Wrote: [ -> ]Thanks will try that when I get home.
yep, just copy these four files.
(2013-12-02, 16:47)mstef Wrote: [ -> ]
(2013-12-02, 16:35)mstef Wrote: [ -> ]http://forum.xbmc.org/showthread.php?tid...pid1560360 - this is the last published 12.x version on this forum/thread.
Allright will do, thanks!
I got the keymaps for adding Apple remote, should I add it follow this Wiki? http://wiki.openelec.tv/index.php?title=...own_remote
I tried the method with uploading (SFTP) the keymap file to rc_keymaps but seems like I dont have write access, solution is to work through that .config folder?
Thanks for the replies. This morning, I uninstalled and reinstalled lirc. I seem to have gotten further on the CIR thing, but it still does not actually work. irw shows nothing, and XBMC, while loading support for remote controls, doesn't receive or register any remote control activity.
my "irfix" script:
sudo modprobe -r nuvoton-cir
echo "auto" | sudo tee /sys/bus/acpi/devices/NTN0530\:00/physical_node/resources
sudo modprobe nuvoton-cir
output from dmesg seems quite promising:
[Mon Dec  2 07:02:11 2013] pnp 00:08: [io  0x0240-0x024f]
[Mon Dec  2 07:02:11 2013] pnp 00:08: [irq 3]
[Mon Dec  2 07:02:11 2013] pnp 00:08: [io  0x0250-0x025f]
[Mon Dec  2 07:02:11 2013] Registered IR keymap rc-rc6-mce
[Mon Dec  2 07:02:11 2013] input: Nuvoton w836x7hg Infrared Remote Transceiver as /devices/pnp0/00:08/rc/rc0/input8
[Mon Dec  2 07:02:11 2013] rc0: Nuvoton w836x7hg Infrared Remote Transceiver as /devices/pnp0/00:08/rc/rc0
[Mon Dec  2 07:02:11 2013] nuvoton_cir: driver has been successfully loaded
[Mon Dec  2 07:02:11 2013] IR NEC protocol handler initialized
[Mon Dec  2 07:02:11 2013] IR RC5(x) protocol handler initialized
[Mon Dec  2 07:02:11 2013] IR RC6 protocol handler initialized
[Mon Dec  2 07:02:11 2013] IR JVC protocol handler initialized
[Mon Dec  2 07:02:11 2013] IR Sony protocol handler initialized
[Mon Dec  2 07:02:11 2013] IR SANYO protocol handler initialized
[Mon Dec  2 07:02:12 2013] input: MCE IR Keyboard/Mouse (nuvoton-cir) as /devices/virtual/input/input9
[Mon Dec  2 07:02:12 2013] IR MCE Keyboard/mouse protocol handler initialized
[Mon Dec  2 07:02:12 2013] lirc_dev: IR Remote Control driver registered, major 250
[Mon Dec  2 07:02:12 2013] rc rc0: lirc_dev: driver ir-lirc-codec (nuvoton-cir) registered at minor = 0
[Mon Dec  2 07:02:12 2013] IR LIRC bridge handler initialized
But then irw registers no events. I'm starting to think my hardware is busted.
i install the newest nightly. when i am playing movies from my nas over nfs, the sound is stuttering.
whats wrong?
Only the sound stutters?
Is your audio output set correctly in the options? Try set it to WASAPI and not DirectSound.
A little more information might also help if you want someone to guess what's wrong! Tongue
Just got mine!! Are you supposed to remove the squidgy pad thing sticking to the bottom when you insert the SSD or leave it there?
(2013-12-02, 17:28)musicman_234 Wrote: [ -> ]Thanks for the replies. This morning, I uninstalled and reinstalled lirc. I seem to have gotten further on the CIR thing, but it still does not actually work. irw shows nothing, and XBMC, while loading support for remote controls, doesn't receive or register any remote control activity.
my "irfix" script:
I've got the same problem on my D54250WYK NUC kit, I can power on the device with my MCE remote, but MCE remote doesn't register anything in openelec xbmc. And I can't shut it down with open elec.
After that I installed windows 8.1 + nuc drivers and xbmc on it, and the remote works ! Shutdown also works.
Put openelec back and the remote just doesn't work.
But I know the hardware isn't busted, just not compatible with openelec.
(2013-12-02, 20:35)tutu Wrote: [ -> ]Just got mine!! Are you supposed to remove the squidgy pad thing sticking to the bottom when you insert the SSD or leave it there?
Leave it there, it's to protect the SSD from pressure.
OK This sucks I have a micro HDMI to HDMI adapter. This thing takes a mini HDMI!! Sad
Edit Just remembered I have a mini display port to HDMI adapter for my old MAC.. hope this works!
Am I right in thinking this is the place to download openELEC daily with the various fixes?
http://openelec.tv/get-openelec/viewcate...tel-builds
When will this be available for ubuntu? I am used to setting up a bare bone minimal ubuntu install with a xbmc ppa Thanks!
What's the recommended integrated memory size?
Is it recommended to enable/disable PCIe ASPM Support/Native ACPI OS PCIe support?
Your link shows the main download page for the stable releases. Here you can find nightlies. Choose generic or intel 64.
http://xbmcnightlybuilds.com/category/openelec-generic/
(2013-11-27, 06:35)docpaul Wrote: [ -> ]My meager contribution to this thread:
For those who start with a virgin Haswell NUC and want to use OpenELEC, based upon the latest and greatest in this thread:
1) ensure your BIOS is latest version (0021): https://downloadcenter.intel.com/Detail_...ldID=23337
1b) leave BIOS with default values
2) download/install lmyllari's patched OpenELEC: https://www.dropbox.com/s/99thzttxxdm9uo...r16441.tar
3) modify the autostart.sh file with the following content:
#!/bin/sh
# Work around NUC CIR issue
# see http://forum.xbmc.org/showthread.php?tid=176718&page=17 and
# https://communities.intel.com/thread/46259 for more information
echo "auto" > /sys/bus/acpi/devices/NTN0530\:00/physical_node/resources
Seems like soon, we'll be able to perhaps simply work with the dev releases of OpenELEC, perhaps as soon as tomorrow as a replacement for step #2.
Feel free to help modify the above.
