When I try to show movies by anything other than title, the list is blank. I have looked at the movies in my library, and all of the metadata is there, so I dont think it is a scraping issue. I tried rescraping, deleting all data (the entire .xbmc directory) and rescraping, no effect. Cleaned the library. Deleted and re-added sources. Nothing seemed to work.
XBMC Frodo 12.2, Gentoo Linux.
Default skin?
Please create a debug log where you switch to one of these views.
Yes, default skin.
http://pastebin.com/Kn6uLdbF
This was with a clean profile (totally deleted my .xbmc directory.
There is one movie in my library, it has all of the information showing correctly on the info page.
Sorry for lots of alsa errors at the top, my config is a wip.
Your debug log doesn't show you scanning your library. Please run a library update and then upload a new log.
Did you create *.nfo files for all your movies? If so, did you include tags in these files for genre, year, etc.?
Deleted the .xbmc directory, added the source, and scaned it.
http://pastebin.com/rjAW8CMi
I am not using nfo files now, I was using them befiore though, and still had the same problem. I deleted them all to give a go at the universal scraper since most people have said it was very good.
Your pastebin link is invalid.
