2013-10-29, 15:25
So I'm a bit stumped on what my next troubleshooting step should be.
I'm on Arch Linux, just updated a couple of days ago after not having done so for about a month, and my remote stopped working after the update.
Confusing bit #1: the update didn't actually update xbmc or lirc. (It did update X, though; only lead I have.)
Confusing bit #2: none of the config files seem to have changed. (Though after triple-checking to make sure they were still correct, I went ahead and recreated Lircmap.xml. No change.)
Confusing bit #3: irw works perfectly, all keys register. However, evdev and ir-keytable both don't give me anything back, no matter which "event" device I pick. EDIT: sorry, that was unclear. ir-keytable identifies my receiver just fine. ir-keytable -t --dev=(event device) returns no data for any of the listed devices, though.
I thought since irw worked, xbmc would work with my remote as long as my Lircmap.xml was correct, but that doesn't seem to be the case. And I don't know why none of my event devices are returning data, though I also don't know how that's relevant to xbmc.
Any advice on what I should look at next?
