2013-10-31, 00:43
Hi guys,
After a friend told be about XBMC 2 months ago, I dived into it and I'm absolutely loving it!!! I had a nice setup where I downloaded TV series to my W7 laptop, which is on the same network as my Raspi (Openelec), and I watched them via XBMC. Since I have max 100 gb free on my laptop I use my 1TB AC Ryan as a HDD which is linked to the Raspi via USB. So far, so good and everything worked fine...the friend helped me with the setup since I'm a total n00b!
However, two weeks ago I moved to my new house and tried setting up everything again! It seemed to be working fine, I can watch everything on the AC Ryan/ HDD perfectly but for some reason i cant play any videos/series that are on my laptop! So i figured it might have something to do with the Raspi/laptop network connection, but the strange thing is...XBMC does see the files on the laptop and XBMC even adds them to my library nicely! I just cant watch any of them! If the connection is wrong...how can XBMC put them in the library? Better yet...I have trailers enabled for movies and those .mov files are in the same movie maps on the laptop. XBMC doesn't play the .mkv/.avi movie files but it dOES play the .mov trailer files..... What is going on here?? I did try to remove/remake the shortcuts to the laptop folders and rebuild the whole library agin...same result! Any suggestions?
Btw I am a beginner/n00b so try to keep it simple! =))
Any help is appreciated! Thanks in advance!
