Full Version: XBMC can't get the right Tv show total Number
Hi
I have a problem with xbmc get the wrong tv show number and Music
https://www.dropbox.com/s/xfn5i2pwxzb8av...t001.png?m
here you see the wrong Number of tv show !!
https://www.dropbox.com/s/asd1ovo5ix0321...t000.png?m
and here the right one on XBMC !!
I have this problem with TV Show and Music !!
what is the problem with XBMC !!
Thanks!!
Edited:The new link is added
Links don't work, but when the number is wrong it is usually because something wasn't scanned into your library properly.
(2013-10-31, 19:05)Vaikin Wrote: [ -> ]Links don't work, but when the number is wrong it is usually because something wasn't scanned into your library properly.
Hi
How to fix it !!
The problem i have is i can't get XBMC get the new show info and the music too so i used MediaElch
then do refresh for the show !
And i get disable the tv scraper add-on (I have XEM and the tvdb working in the same time !!!)
And i think these make XBMC confuse !!
And this problem in the Music too (Two scraper working in the same time)
I add new links for the photos Now
Thanks a lot
