2013-11-01, 11:41
same as URL INSTALLER FOUND HERE but for your backup userdata to www.userdatainstaller.com
you need to copy a link to a public zip url and it will auto install the plugin for you
below is how it works the good this is you can create and use a url shortener service so you can either install one plugin at a time or copy your whole setup and install in one
example:
copy all your userdata/addon_data that you want zip it up put on your dropbox public folder
use a URL shortner :
i.e
http://tiny.cc/my_userdata_backup (use something that you will never forget)
no need to shh over anymore
GET IT HERE (no GA or Ads
below is example of urlinstaller but userdatainstaller works the same way
example:
i.e
