Full Version: Hide Settings?
Hi there,
first: Thank you very much MarcosQui for the amazing ACE Skin! Very very great work.
I've one question:
In the settings there is a function to hide the "Settings" in the main menu. I'd like to use this function, but how can I reverse this? Is there any key combination available to make Settings visible when I disable it in the main menu?
And another question:
How can I hide the "Shutdown" function in the main menu? To shut down the htpc I use the shutdown key on my remote - so I don't need it in the main menu.
Thank you
hitting the S key on the keyboard will bring up the menu you are looking for.
