Full Version: XBMC can't connect to NextPVR
Hello,
I have NextPVR installed on my HTPC and everything works fine, but when I try to connect with XBMC I get the error "Connection Failed! Incorrect PIN?.
When I try to open "http;//serverip:8866" everything works fine. The needed programs from NextPVR are allowed in my firewall and I also tried to disable the firewall on both server and client.
In the XBMC logs this is the only error I can find:
Quote:13:57:11 T:6224 ERROR: ADDON: Dll NextPVR PVR Client - Client returned bad status (1) from Create and is not usable
13:57:11 T:6224 WARNING: PVR::CPVRClients::UpdateAndInitialiseClients - failed to create add-on NextPVR PVR Client, status = 1
13:57:11 T:6660 NOTICE: Thread CAddonStatusHandler:pvr.nextpvr start, auto delete: true
And this is a part of the web.log file from NextPVR:
http://pastebin.com/dtJwSPWu
It says "Login Failed" what I don't understand because the Acces PIN should be the same.
So, what am I doing wrong? I hope someone can help me with this problem
Thanks,
Mathijs
While troubleshooting a different problem I noticed on the nextpvr forum that someone mentioned a bug where the pin code isn't recognized if it's changed form the default 0000. Might try changing back to 0000 if you've changed it.
I changed it back to 0000, but it's still giving me the error. Is there a config file where you can see/edit the PIN so I can know for sure it's 0000?
Thanks,
Mathijs
Oke, I reinstalled the program and now everything works fine. Smile
Thanks for your help.
Mathijs
(2013-11-02, 15:58)awp0 Wrote: [ -> ]While troubleshooting a different problem I noticed on the nextpvr forum that someone mentioned a bug where the pin code isn't recognized if it's changed form the default 0000. Might try changing back to 0000 if you've changed it.
For the record - there was a patch posted a few days ago to fix this issue with changing the pin number. It can be found here: http://forums.gbpvr.com/showthread.php?5...post466536
Cool, thanks Sub3.
