Full Version: Right mouse button exits XBMC
Hello there,
I just installed most recent daily builds (4th and 3rd of Nov) to check MediaCodec HW decoding and found out, that on both of them right mouse button exits to main system screen. It happens on Android 4.1.1 (Rockchip 3066 tv stick). Mouse I use is Measy RC9 air mouse. Just to verify I also installed build from 23rd of Oct and it works fine, RMB works as back button.
I don't know if it is a bug or intended change, but I suggest to fix that to make RMB a back key again. On TV stick I hide system bar on startup to let XBMC be fullscreen, so I don't have any way to go back other than RMB.
Mele Flymouse F10 right mouse button also exits & minimizes xbmc in latest nightlies on MK808, very frustrating.
I'll check that out
Its because Right Mouse click functions as a back button.
*IF* whatever air mouse you are using is actually sending right button clicks, it should be sovled in latest nightly.
