Full Version: Help with Android original Confluence
Hello guys,
I want to make some small changes on the original skin of my Gotham new XBMC in my Android device (Minix G4) but I can´t find a way to do this because there is no Confluence folder inside my addons folder.
Where are the xml files when you use the default skin?
I tried to extract the skin.confluence folder from the apk and then I compressed into a .zip but XBMC said that the structure is not correct when I try to install it by importing from a .zip file.
I edited addon.xml with a new name and id before that and still not working.
Any idea?
Thank you!!!
Anyone please?
This can´t be so difficult...
Or maybe someone can put a zip version of the original Confluence for Gotham?
