Hi I have aeon nox skin and I love it but my biggest issue is when you go back and forth through videos to home screen to anything the list view changes. I would like the list view to always be lets say for example info wall. Is there a way to do this its very annoying that i have to go to the left and change the view every time. Please help
Hey adiaz,
Once you set the view you like, for example movies. It should remember what view you set for your movies every time you go back into it.
The same goes for all the TV shows and music for example. At least that's how it works on my system.
Make sure that your XBMC->users folder doesn't have admin only privileges, also make sure the users/guisettings.xml file is not set to read only
