Doesn't show anything about this. All my addons shows as broken because I import urlresolver, that imports youtube and that imports parsedom which is missing from frodo.
The add-on forums are filled with people reporting 'dependencies not met' and a large chunk of the add-ons are broken. What happened here?!
This module is empty on xbmc servers causing "dependencies not met"!
Temp fix: install as zip
http://bit.ly/moduloxbmc and restart xbmc.
thanx for the report!
looks like we have a problem with our mirroring system, we'll look into it.
Somewhere in our work on the mirroring system something went wrong. Martijn regenerated these addons and they are now available on the server again.
Thanks. I should report it yesterday
(2013-11-08, 16:23)fightnight Wrote: [ -> ]This module is empty on xbmc servers causing "dependencies not met"!
Temp fix: install as zip http://bit.ly/moduloxbmc and restart xbmc.
How to install this on android Nexus 7, stock unrooted? Can I install as an update in stock recovery?
