I'm seeing a very weird issue when both PVR Clients are enabled.
On XBMC start-up only the channels from "PVR IPTV Simple Client" are listed, all the channels from "Tvheadend HTSP Client" are not listed.
If i configure "Tvheadend HTSP Client" add-on, don't change anything just OK in the configuration page the add-on restarts and all the missing channels are added back but on a XBMC restart the channels from "Tvheadend HTSP Client" are missing again.
I'm running XBMC 12.2 with: "PVR IPTV Simple Client" - v 0.4.0 - the latest one && "Tvheadend HTSP Client" - 3.4.27
Did anybody see anything similar?
If I keep Only one PRV client running at any moment everything works fine.
Looking forward to your feedback.
Sadly this bug is still a problem, tvh-hts or tvh pvr addon + iptv-simple (maybe others too) wont work at Helix. Still the same problem :/
I confirm too ! same problem with last OpenELEC/Kodi ..
But I resolved this by using only Tvheadend, and remove IPTV simple.
You've got now into Tvheadend all you need to add IpTV channels with url and rtsp url too with transcoding ...
due to the limitations of tvh it could not replace the iptv simple addon (m3u8 for example)
Namerp
Yes it can,
see
For example:
pipe:///usr/bin/ffmpeg -loglevel fatal -i http://c01cp.vds-is.castup.net/990310142-123.flv/smil:990310142-123.smil/chunklist_b1850000.m3u8 -vcodec copy -acodec copy -metadata service_provider=IBA -metadata service_name=Ch1 -f mpegts -tune zerolatency pipe:1
(2015-01-26, 19:09)dhead Wrote: [ -> ]Code:
maybe i´am doing some thing wrong but it is not working at all, the lack of any documentation/guides made it not easier
-added a network
-add a mux (at the iptv network) with this url and save
pipe:///usr/bin/ffmpeg -loglevel fatal -i http://daserste_live-lh.akamaihd.net/i/[email protected]/master.m3u8|X-Forwarded-For=91.63.136.21 -vcodec copy -acodec copy -metadata service_provider=IBA -metadata service_name=Ch1 -f mpegts -tune zerolatency pipe:1
- url get not saved , if i add it again i get a deadlock at tvh
Namerp, you're close.. Try with the -re option.
pipe:///usr/bin/ffmpeg -loglevel fatal -re -i
http://c01cp.vds-is.castup.net/990310142...50000.m3u8 -vcodec copy -acodec copy -copyinkf -fflags +genpts -metadata service_provider=IBA -metadata service_name=Ch1 -f mpegts -tune zerolatency pipe:1
I'm having the same problem, running latest Openelec (5.0.2) and Tvh 3.9.2496~gd386ed0.
Added network and mux and i get this in tvh log:
2015-02-14 02:54:26.002 spawn: Executing "/usr/bin/ffmpeg"
2015-02-14 02:54:26.005 subscription: 0013: "scan" subscribing to mux, weight: 2, adapter: "IPTV", network: "IPTV", mux: "test", hostname: "", username: "", client: ""
2015-02-14 02:54:26.024 spawn: Error splitting the argument list: Option not found
Tried with a couple of URLs, I guess some unrecognized option in ffmpeg?
(2015-01-26, 19:09)dhead Wrote: [ -> ]@Namerp
Yes it can, see
For example:
Maybe a n00b question, but I couldn't find where should I put this line?
In tvheadend I have created network MyIPTV and created mux with URL as in code section, and I got this
Quote:2015-04-26 17:52:52.432 mpegts: pipe:///usr/bin/ffmpeg -loglevel fatal -i http://c01cp.vds-is.castup.net/990310142...50000.m3u8 -vcodec copy -acodec copy -metadata service_provider=IBA -metadata service_name=Ch1 -f mpegts -tune zerolatency pip - tuning on IPTV
When added like this, I cannot access my THheadedn anymore, so I have to manualy delete from config file.
Good news.
BTW. I figgered out, this worked for me
pipe://ffmpeg -loglevel fatal -i http://edge3.volim.tv/live/pink.stream/playlist.m3u8?hash=0b31804c266b6708288ab04beef25282d4506f79 -acodec copy -vcodec copy -bsf h264_mp4toannexb -f mpegts pipe:1
I have changed to pipe://ffmpeg removing path to ffmpeg and it worked.
Hi, I have Openelec on a RPI and I want play IPTV via .m3u file on it and can record channel.
With TVheadend it's possible.
With the command line you post, it's possible?
I need install frontend tvheadend on Kodi and Simple IPTV Client on Kodi? Or backend tvheadend and simplle iptv client on Kodi?
Where I need to type your command line? On Openelec?
How can I put the http address of my channel?
Thanks you.
