2013-11-08, 20:08
Hello,
I have been trying to figure out this problem so far on my own. However, I have now been struggling with it for over a day and still not luck. So I was hoping to get some help.
Anyway, when I try to Update Library, XBMC will skip over my Movie Library and only SCAN my TV Shows. However, if I just go to the Movie folder and select Scan for New Content, the scraper works just fine.
Here is a copy of my logs.
http://xbmclogs.com/show.php?id=81724
I have been looking at them for a decent amount a time and I believe that my problems occurs due to this line:
05:23:14 T:146911232 DEBUG: VideoInfoScanner: Skipping dir 'smb://192.168.1.120/Movies2/' due to no change (fasthash)
I have no idea what fasthash means or anyway to correct the issue. Any help would be amazing at this point. I am really at my wits ends.
Solutions I have tried with no success:
-Delete Database file and re scrape content.
-Made certain Movie Folder had been modified since last scan
Thanks in advance!
Thanks in advance!
