(2018-01-18, 02:12)dmdsoftware Wrote: [ -> ] (2018-01-17, 17:52)thall72 Wrote: [ -> ] (2017-12-29, 20:04)Habskilla Wrote: [ -> ]Anyone get this to work on the xbox one?
I did for about three days but now it’s broke again.
Any suggestions dmdsoftware?
Describe broke? What was working that is not working?
I can’t seem to get it to enroll my account. I’ve done it the same exact way I’ve done it on all the other platforms I’ve ran kodi on but for some reason on the Xbox it just keeps giving me a error.
(2018-01-18, 06:16)thall72 Wrote: [ -> ] (2018-01-18, 02:12)dmdsoftware Wrote: [ -> ] (2018-01-17, 17:52)thall72 Wrote: [ -> ]I did for about three days but now it’s broke again.
Are you using gdrive or gdrive-testing?
I’m using gdrive...not the gdrive testing.
(2018-01-18, 21:54)thall72 Wrote: [ -> ]I’m using gdrive...not the gdrive testing.
There might have been an issue at the time with the Google Apps. Can you try again?
If it fails, can you try installing gdrive-testing. This uses a different enrollment process that doesn't use Google Apps.
use this version:
http://dmdsoftware.net/repository.ddurdl...0.8.62.zip
thanks for the addon
im using win10/ v0.8.52.
for some reason i can't see the subtitle of an .mkv movie in kodi/gdrive, but i can still see them on google drive's web version.
https://drive.google.com/file/d/1ZQkxL0I...KAqQW/view
Is there any settings I didn't do in order to see the subtitles?
thanks.
(2018-01-21, 12:56)tamashika Wrote: [ -> ]thanks for the addon
thanks.
Enable close caption in plugin settings.
Hi.
I intend to create .strm files with video addons inside Kodi.
The idea is to save these .strm in Google Drive to access them from different devices (as a backup of my video library).
Does this addon help me do this? I will be able to visualize video files only saving in .strm files previously created by me in Kodi?
The idea is not to save video files in google Drive because they take up a lot of space.
Regards!
(2018-01-25, 04:21)tamashika Wrote: [ -> ] (2018-01-25, 04:21)tamashika Wrote: [ -> ]"Enable close-captions tracks" is enabled, but there is still no subtitles.
https://imgur.com/WcTz60A
There are three subtitles in the mkv file:
https://imgur.com/eAf4ddE
Also, is it possible to change audio track in this addon?
https://imgur.com/a/K5GEu
thanks
嗨,看你的圖片好像是台灣人,我蠻喜歡這附加元件,這附加元件,使用內置的kodi播放器兼容性比較好。
google translate:
Hi, see your picture seems to be Taiwanese, I like this additional components, this additional component, built-in kodi player compatibility better.
@dmdsoftware I'm back. I see there has been no movement on scheduled STRM's as yet.
Would it be easier to implement a way of adding the Gdrive as a source like
cguZZMan has implemented in his Gdrive addon. That way works but seem very slow and maybe you can get a simillar function running faster?
He also has a less confusing way to authorise.
(2018-01-27, 17:35)beljim7419 Wrote: [ -> ]@dmdsoftware I'm back. I see there has been no movement on scheduled STRM's as yet.
Would it be easier to implement a way of adding the Gdrive as a source like cguZZMan has implemented in his Gdrive addon. That way works but seem very slow and maybe you can get a simillar function running faster?
Work is still being done on the automatic STRM updating via scheduler.
thanks
I'll look into why the closed captions are not loading on that particular video.
There is no way to change the audio track. It is not possible with the way KODI is setup.
I’m on a MiBox and for the past couple of days I have been having that exact same bahviour
Now I can’t seem to be able to re-enroll my account
I’m using gdrive-testing though
This one said (whilst enrolling) to enter a local web address, I complete steps 1 (sometimes step 1 fails) and then step 2
Then after I submit I get a 400 error at the same local server 🤔🤔
This is a question that probably has been asked a million times (but for the life of me I couldn't find an answer):
I've encrypted my gdrive folder with rclone, is there a way to Gdrive for Kodi to play the files inside that?
