2018-12-10, 15:27
(2018-12-10, 01:02)keithcq71 Wrote: [ -> ]When I try to authorize gdrive with another device I keep getting “sign in with google temporarily disabled for this app”They were using the old version
(2018-12-10, 01:02)keithcq71 Wrote: [ -> ]When I try to authorize gdrive with another device I keep getting “sign in with google temporarily disabled for this app”Yep same here
(2018-10-17, 12:07)keithcq71 Wrote: [ -> ]Is it possible to have strm stored in my google drive for playback? Also I update a lot and manually updating is the only option due to no automic strm creation ? I prefer this addon over the other one .
(2019-06-02, 22:47)scofield272 Wrote: [ -> ]Hi all
I've been using gdrive for years now but now i'm getting a wired error when i'm trying to log to my account via gdrive "login information is incorrect or permission is denied"
any advice what should I do? thanks.
(2019-06-03, 09:05)scofield272 Wrote: [ -> ](2019-06-02, 22:47)scofield272 Wrote: [ -> ]Hi all
well, It seemed to be fixed. i wonder what that glitch was..
(2019-06-17, 00:10)drive0001 Wrote: [ -> ]bad changes in gdrive
photos and videos from GOOGLE PHOTES will not szhow in gdrive , is it possible to adjust plugin to work after that changes ?
It is needed if i upload only by photos and want to watch in kodi
https://www.blog.google/products/photos/...gle-drive/
"Changes to automatic sync between Google Drive and Google Photos
Starting in July, new photos and videos from Drive won’t automatically show in Photos. Similarly, new photos and videos in Photos will not be added to the Photos folder in Drive. Photos and videos you delete in Drive will not be removed from Photos. Similarly, items you delete in Photos will not be removed from Drive. This change is designed to help prevent accidental deletion of items across products."
(2019-06-25, 19:44)kenmills Wrote: [ -> ]Hi there,Weird... files just all started playing now... After about 16 hours of not working.
Awesome add-on, thanks!
I started using Gdrive today but i cannot seem to play any video from my google drive. I click on a movie filename (after authenticating my account and navigating to the correct folder), the Working animation spins for a few seconds and then disappears. The movie does not play.
I can see all my files, I just can't play them. I have tried on an android device Kodi 18 and My Windows computer Kodi 18; latest Gdrive add-on. All files are MKV format.
Movies won't play directly from the Gdrive addon or via the exported strm streams.
It seems it is only the 'Original' quality files that won't play. If I set the setting in Gdrive, that says "Force Prompt for Quality Selection" before playing file, and I choose 1080p or anything other than Original Format, it works fine. I have "Never Transcode" selected also.
This is the same behavior for 1080p files, not just 2160p files; if I choose original it spins and stops. If I choose 1080p, it plays.
Has anyone seen this issue before?
Cheers,
Ken
(2019-06-26, 01:03)kenmills Wrote: [ -> ](2019-06-25, 19:44)kenmills Wrote: [ -> ]Hi there,Weird... files just all started playing now... After about 16 hours of not working.
Cheers,
Ken
All good I think.
Is there a download limit for Google drive each day? Maybe after you reach your upload limit?
Cheers,
Ken
plugin.googledrive
plugin.video.gdrive
(2019-06-27, 07:24)DaVu Wrote: [ -> ]@kenmills
Just to bring your attention to it. This is the wrong thread for the problem you have, because you are using a different addon. From the log snippet above you are using:plugin.googledrive
This thread here is about a different add-on providing a similar service. But the add-on id is different:plugin.video.gdrive
So I would recommend to stick to the other thread you already posted in.
