2015-04-30, 00:01
(2015-04-29, 21:24)RuudM Wrote: [ -> ]Aha v6.12
22:45:19 T:2160 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.gdrive-testing/folder.jpg?content_type=image&instance=gdrive1&mode=search
22:45:19 T:2160 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.gdrive-testing/folder.jpg?content_type=image&folder=PHOTO&instance=gdrive1&mode=index
22:45:19 T:2160 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.gdrive-testing/folder.jpg?content_type=image&folder=SHARED&instance=gdrive1&mode=index
22:45:19 T:2160 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.gdrive-testing/folder.jpg?content_type=image&folder=STARRED-FILESFOLDERS&instance=gdrive1&mode=index
22:45:19 T:2160 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.gdrive-testing/folder.jpg?content_type=image&folder=0BxCqg4tP7e6JWXlyaHJwbXBHOWM&instance=gdrive1&mode=index
Installed now stable version 6, which is working, also on Kodi 15.0 beta. Seems that something is missing in 6.12
Can I get a clarification from folks using "slideshow" if you are invoking slideshow by 1) right-click on folder in plugin, select slideshow, 2) right-click on a photo in the directory in the plugin, select slideshow or 3) select slideshow in XBMC itself. I suspect #3 would have issues.
It is good that you mentioned it worked in 0.6 (stable), because this is the last time I ran through the regression bucket of test cases. I run them (time consuming process) whenever I promote a release to stable. I haven't tested slideshow this week, so it is conceivable it broke. Which is better news then to think it is something with KODI 14/15.
