(2017-04-21, 18:14)dmdsoftware Wrote: [ -> ] (2017-04-21, 13:02)bearing Wrote: [ -> ]Hi there ddurdle, I'm having issues accessing my Gdrive. I have successfully activated the account using my own OAUTH2 authentication but when I click on my enrolled account I am taken to a generic folder that isn't mine.
The folder I see looks like this:
<Testing - manual run of change tracking build STRM>
[SEARCH]
[show all Shared Files & Folders]
[show all Starred Files & Folders]
[show all Videos]
Any ideas where I may have gone wrong?
The Google instructions for using your own OAUTH2 has changed and the steps in the instructions won't work anymore. I haven't had time to review what has changed and what needs to be updated in the instructions.
Ahh, thanks for that.
I went with that route because for some reason I can't get the standard way to work.
(2017-04-21, 19:05)bearing Wrote: [ -> ] (2017-04-21, 18:14)dmdsoftware Wrote: [ -> ] (2017-04-21, 13:02)bearing Wrote: [ -> ]Hi there ddurdle, I'm having issues accessing my Gdrive. I have successfully activated the account using my own OAUTH2 authentication but when I click on my enrolled account I am taken to a generic folder that isn't mine.
[SEARCH]
[show all Videos]
is there an error when you use the regular way?
@DDurdle I could have sworn I saw file sizes beside my video files. Now its gone. Is it under filter or other settings?
How do I create a playlist using all media in a particular folder? Can I use this playlist as a screensaver?
Sent from my SM-G920P
You got a change log anywhere? Should I be using stable version or continue with testing? Good work.
Sent from my ONEPLUS A3003
(2017-05-06, 16:14)delboy666 Wrote: [ -> ]You got a change log anywhere? Should I be using stable version or continue with testing? Good work.
Sent from my ONEPLUS A3003 (typie typie)
I just pushed out a few changes that were in testing a long time that were tested and ready to be promoted. Nothing big. So right now the two are identical
Now that they are in sync, I'm working on some new changes.
Thanks for the reply. I'll stick with testing if there's more goodies on the way. Great work. Really appreciate what you have achieved and shared with us all.
(2017-05-06, 16:51)horstepipe Wrote: [ -> ]Thank you!
How do you estimate the chances to get this working some day?
https://github.com/ddurdle/GDrive-for-KODI/issues/113
Yes, this is one of the first of the new changes I'm working on. But I will need someone to test. I don't have any KODI instances with a KODI library. I don't use the STRM process at all.
Have you used slack before? I'm thinking of creating using a slack group.
(2017-05-06, 17:32)dmdsoftware Wrote: [ -> ] (2017-05-06, 16:51)horstepipe Wrote: [ -> ]Thank you!
I use kodi and would be happy to test anything that needs it.
Nice to hear, I'd be happy to help with testing. I can test both, a native Kodi library and with an Emby for Kodi library.
Yes I'm actively using Slack, I'll PM you my email for a team invite.
