2013-11-09, 19:59
Hi.. I want to upgrade to XBMC Frodo 12.2, since last time i've tryed with the automatic ubuntu (12.04) update and I get a very bad result (frodo was very unstable at that moment). As it was quite difficult to reinstall XBMC 11.0 now I want to be sure 12.2 is working properly before installing it in my computer.
I've downloaded the latest sources, I've run
./configure
(needed to install tinyxml library and another one can't remember the name)
and then run
./make
after that I have tryed the portable mode:
./xbmc.bin -p
XBMC run correctly but as soon it finish the startup, the shutdown dialog is displayed, if I press ESC then the dialog popup again, and again and again...
any Ideas?
./configure
and then run
./make
./xbmc.bin -p
any Ideas?
