when it comes to button scroller is there only one avail per window, xmlfile? or can you have 2-3 button scrollers
how many animations can be for a single control?
is this the same for a window?
thanks for any help!
jimk
you can have more than one buttonscroller per window (at least i can't see anything preventing this).
there is 6 animations for controls:
windowopen
windowclose
visible
hidden
focus
unfocus
there is 2 animations for windows:
windowopen
windowclose
in addition, there is an extra one for controls available as a shortcut:
visiblechange
this just defines the visible animation in the usual manner, but automatically generates a new hidden animation as the reverse of the visible animation.
eg:
<animation effect="slide" start="100,0" time="100">visiblechange</animation>
is equivalent to:
<animation effect="slide" start="100,0" time="100">visible</animation>
<animation effect="slide" end="100,0" time="100">hidden</animation>
it should be all in the online manual
cheers,
jonathan
i saw them all in the manual but there was no set limit as to how many entries you could have. i know it should be obvious that most would only use 1-2 but i wanted to know before i set it up to allow only 4 but i guess there may be a situation that you would need all 6 for.
thanks for you help
the editor is looking better every day
