2013-11-10, 12:58
Hi to all,
I have my XBMC setted with DXVA2 ON because I love the noise reduction filter of my ATI 7770 graphic card.
I essentially use my HTPC with BluRay files but I have some DVDs (PAL and NTSC) stored in folder structure.
When I play those kind of files XBMC works without DXVA and I use those settings to obtain a fantastic quality:
I miss a little bit DXVA denoising filter but the deinterlace and global quality are fantastic.
Anyway I've some PAL DVDs stored like MKV. I've created those MKV files with MakeMKV with the script AUTORIP DVD.
Well, when I play those mkv XBMC seems to works forcely in DXVA mode (look at the lower picture) ....
In this mode I've very low quality! Bad oblique lines and some stutter (like lost frames).
There is no way to fast deactivate DXVA when mkv is playing... I've to stop reproduction, go in the system settings of XBMC and manually deactivate DXVA.
This is very frustrating.
There is a way to tell XBMC to work with MKV interlaced files like it works with DVDs in folder structure?
many thanks.
many thanks.
