Running Gotham on 10.9 Maverick.
No issues so far, music sound better no hickups between tracks.
1 weird issue, The music folders sources are the same since ever.
Upgraded to Mavericks and did a clean Gotham install. All music is scanned and available.
In Artist | Album | Track view, some albums do not show up as an Album, however, all tracks are in the DB and visible through the All Albums view.
https://dl.dropboxusercontent.com/u/1451...mc.log.zip
log is 8.5MB
don't post snippets on the forum
Mind condensing down to the problem? I can't tell from the screenshots exactly what the issue is.
i.e. which album doesn't show up in the library? Where do the tracks from that album show up? What is listed as "Album" when you go to Song Information on that track?
A lot of abums do no show up under album view (screenshot 1)
However, the track that are on the album do show up under all Albums (Screenshot 2)
Moon Safari is not in album view, but all tracks are visible under all
Moon Safari (CD) is shown under album view.
This happens to al lot of albums (rough guess, 50% of the albums)
Deleted database, rescanned source. Some albums still dong show, only the tracks show in all albums
And what do those tracks have their Album set as (Song Information on those tracks).
All tag info is read correctly
Album is read correctly.
Song playsfine. Path is shown correctly
Happens to dozens of albums and it appears to be the same ones after complete rescan.
So if I get you correct, the tracks:
1. Have album and artist tags correctly read, as you can see them from Song Information inside of XBMC.
2. Do not show up under Music->Artists->[Artist name] list of albums.
3. Do show up under Music->Artists->[Artist name]->All Albums.
Any chance you could supply a file that shows this behaviour? If so, please create a ticket on trac and cc myself and night199uk.
Jonathan
Yes exactly.
Prior to mavericks and Gotham all worked well
I'll supply some samples.
posted PM,
Test build with same library did not show any new albums.
I'm having the same issue with the Gotham nightly on Linux.
If you need any debugging I can provide.
