2013-11-11, 11:44
Hello, yes I'm a noob and I have looked for similar threads so apologies if I am repeating an obvious question but...
I have an Android box that came with xbmc already installed. I believe it runs on Linux and is a 'MX' box. Xbmc will pick up a wifi signal but won't connect to it. I've been told that if you go to the Android home page and change the settings there then xbmc will connect afterwards.
My issue is that my box boots straight to xbmc, how can I get to the original Android menu??
The power button in bottom left corner turns the box off, others just shut xbmc down and kick you back to the home page.
Again, sorry if this is the wrong place for this question or if it's the millionth time it's been asked- I just want my unit to do what it's supposed to
