2013-11-11, 20:59
Hi.
I purchased this box to run xbmc.
XstreamTec Linux XBMC Midnight M3 - IPTV Mini Web Streaming HTPC Media Player.
its running v 12 (Frodo)
just to be clear - this is the link
http://www.amazon.co.uk/gp/product/B00CA...escription
the box is connected to my television via a composite (i.e. red yellow white) connection not an hdmi box.
i had a similar box which used to run android, and that worked with this tv just fine.
However, when i power on the linux/xbmc unit i get a garbled screen (as if the resolution is too high for the tv, i can see the (garbled) xbmc logo). ive tried attaching the box (temporarily) to a friends hd tv to see the pucture (fine)but even changing the resolution in xbmc (which boots up fine) does not fix the problem. its fine when its connected via hdmi but the composite connection just gives out a garbled screen.
is there a way i can ssh into the unit (it gets on the network fine) and change a resoution setting not normally available via the xbmc menu. im not after a sky high resolution, just want the box to work with this old television. I'm hoping its not a hardware issue - as the same box ran android no problem, but i didnt like android as an os and would be happier using this linux/xbmc setup,
any help appreciated.
mark
mark
